Lucas shut up ina bottle - Mustang Evolution
Old 09-23-2013, 10:04 PM   #1
anyone have experience using that lucas **** to quiet lifters and such. would like to hear my exhaust over my engine haha tick tick tick wine wine wine
Mustangman705 is offline   Reply With Quote
Old 09-23-2013, 10:07 PM   #2
1slosix's Avatar
yeah...it works pretty well
carving corners like a boss
Old 09-23-2013, 10:15 PM   #3
did you use it on your mustang and for what... I know I should figure out what the tick is and get it taken care off but I just want to keep the car alive for a while...eventually guna drop a fully built motor in but not sure when that will be exactly
Old 09-23-2013, 10:19 PM   #4
1slosix's Avatar
yes i used it in my mustang...and for ticking
Old 09-23-2013, 10:23 PM   #5
I assume it stopped the ticking if you say its good... do you know what was ticking, how many treatments did you do.... what bottle did you buy
Old 09-23-2013, 10:26 PM   #6
1slosix's Avatar
it stopped it...and then i found another ticking which was an exhaust leak. i'd assume it was a sticking lifter...i did one treatment and bought the stabalizer bottle
Old 09-23-2013, 10:30 PM   #7
thanks for the reply man ill be buyin a bottle in the morning.... did you drain any oil before adding or just poor it in... I need an oil change soon but I think ill buy two bottles, add one tmrw then another when I change my oil
Old 09-23-2013, 10:47 PM   #8
1slosix's Avatar
i waited till my oil change so i didn't need to drain. although i will say i now run a bottle of zmax in my oil every change and it runs great. i also have zmax in my trans as well. you may look into it once you get your lifter issue taken care of.
Old 09-23-2013, 11:01 PM   #9
do you think it unstuck the lifter or just masked the problem....
Old 09-23-2013, 11:28 PM   #10
1slosix's Avatar
who knows...i haven't had this issue since an that was 3 oil changes ago
Old 09-23-2013, 11:30 PM   #11
did you use the synthetic or the heavy duty
---------- Post added at 11:30 PM ---------- Previous post was at 11:29 PM ----------
do you put conventional oil or synthetic in your car
Old 09-23-2013, 11:32 PM   #12
1slosix's Avatar
i used the HD...and i run semi synthetic motorcraft
Old 09-24-2013, 12:59 AM   #13
Mfore33's Avatar
I've seen the old late night commercials claiming that z max was liquid god in a bottle. They took a inline 300 ford motor and added z max to it. Then they drained the oil and took off the cover to the pushrods and started spraying water in it. The motor never locked up but I just can't believe that stuff is that good. If it was every one would use it. Just seems too expensive to use as directed. Now I'm no expert and if it works for you that's great.
Old 09-24-2013, 01:23 AM   #14
Slow4V's Avatar
What exactly does Zmax do
Old 09-24-2013, 02:31 AM   #15
Haha. I remember that... An excellent choice of an engine to use.
Those straight sixes were the damndest things, they would run a good long time with minimal maintenance. That engine was the "power plant of choice" for the UPS fleet for many years. As well as, too numerous to list, industrial applications.
One hell of an engine...
That engine would have stayed running had they submerged it in a pool of mud.
Even without the Z max...
Long enough to get the footage that they needed for their "infomercial" anyway.
Neat demonstration... On the durability of a Ford 4.9 l six.
These crazy additives have been on the market for years. A lot longer than I've been around.
Slick 50 was the "latest and greatest" for my generation. Used to be only available through "dealers". Not available in any stores. You had to buy it out of the trunk of some dudes car... Like a dope deal...
Wasn't buying it then, and, even though I've wised up quite a bit since my youth... Im still not buying it...
Old 09-24-2013, 10:42 AM   #16
any one else have experience with lucas hd
Old 09-24-2013, 04:07 PM   #17
well used a bottle of lucas today, and drove about 20 kms... doesn't seem to have made any change haha fuuuuuu... starting to think I should just build a 2v over the winter or get a crate engine this spring
Old 09-24-2013, 04:28 PM   #18
I just noticed today, how much noise the PCV valve makes...
Old 09-24-2013, 04:34 PM   #19
ahhh I changed mine just last week and cleaned my maf ... ill take a video of my engine running and see if anyone can tell me whats wrong
03:34 PM
