Which sparkplugs to get - Mustang Evolution
Old 09-24-2013, 08:45 AM   #1
PBrown92's Avatar
I am going to be replacing the sparkplugs in my 97 gt. I just bought the car so I'm not sure if it's ever been done. I'm just doing some basic maintenance. I've heard of the dreaded spark plug problems with this year of mustang and don't want to put flawed sparkplugs back in.
1997 black GT
BBK CAI
SLP Loudmouth cat back
PBrown92 is offline   Reply With Quote
Old 09-24-2013, 09:10 AM   #2
1lowGT's Avatar
Motorcraft
---------- Post added at 10:10 AM ---------- Previous post was at 10:08 AM ----------
The only problem with these is people tend to mess up the threads and they blow out then you gotta get a new cop. Not on your 97 though. You'll be fine just get motorcraft and be careful don't tighten them too right.
Old 09-24-2013, 10:01 AM   #3
I've run Autolites in every single car I've ever owned and have yet to have a problem. They are VERY inexpensive too.
*** Get a torque wrench when you do your plugs*** Factory spec is 12 ft lbs. Harbor Freight sells a 200 in lb torque wrench for $20 which is perfect for this. Just set it to 144 (145) in lbs and you are G2G in that regard. If you do not use a torque wrench you are asking to overtighten them and have them blow out.
Old 09-24-2013, 10:24 AM   #4
PBrown92's Avatar
Thanks for the recommendation. I think I'm going to go with the auto lite iridium plugs.
1997 black GT
BBK CAI
Old 09-24-2013, 10:39 AM   #5
I bought NGK G POWER plugs, there not expensive and I hear they are just as good as any other ... I tightened mine down to 12 lbs.. doesn't seem that tight but considering there is only a few threads in the head its tight enough.... and when you take your plugs out your not going to be to worried if you bought cheap plugs or not, anything will be better then the **** you pull out haha I know mine looked terrible
Mustangman705 is offline   Reply With Quote
Old 09-24-2013, 02:34 PM   #6
Slow4V's Avatar
NGK TR55 are suppose to be like magic for these motors
Old 09-24-2013, 03:57 PM   #7
yah that's the G power.. that's what I got there cheap like 6 bucks each
» Members Mustangs
Elenor
bowtietr
Ted
whyxitx
Add your Mustang
07:08 PM
