Need to lower my car asap! - Mustang Evolution
Old 09-24-2013, 03:17 PM   #1
Rich04's Avatar
I want it low, but not to the point where I'm scraping my car everywhere. Can i lower it more then 1.5" without problems ?
Rich04 is offline   Reply With Quote
Old 09-24-2013, 03:27 PM   #2
MidnightBlueGT's Avatar
Yeah 1-1.5 is good for a daily driver. Mine only has trouble at 1 with my front lip or mufflers on occasion. Its pretty much just learning to drive low
Old 09-24-2013, 03:28 PM   #3
Slow4V's Avatar
Mines at least 2" or lower all around with 18X9 / 18X10 and I had to roll my rear fenders , and I scrap and bottom out on speed bumps
It's driveable.. I've seen lower
Old 09-24-2013, 03:36 PM   #4
Rich04's Avatar
I wana get rid of the nasty gaps is all, i always drive with caution. am i better off cutting, is it hard? or should i just get new springs ?
Old 09-24-2013, 03:39 PM   #5
Doe_Rae_mi's Avatar
It's better to just get springs, but you can cut them
Old 09-24-2013, 03:41 PM   #6
Rich04's Avatar
If its not too hard i might wana try before getting springs
Old 09-24-2013, 03:45 PM   #7
A good amount of people cut their springs an say it rides good still.
Old 09-24-2013, 03:45 PM   #8
Slow4V's Avatar
Cut mine , no ride problems
But my springs are different than the GTs
Old 09-24-2013, 03:47 PM   #9
Doe_Rae_mi's Avatar
It's not hard. u have to cut It with a wheel cutter. Cut your front springs on the bottom end the rear springs from the top
Old 09-24-2013, 03:48 PM   #10
Slow4V's Avatar
It's not hard u have to cut with a wheel cutter
I can usually do springs and cut them in under a hour or 2 tops
Old 09-24-2013, 04:13 PM   #11
heat them with a torch and the weight from your car will make it lower
Mustangman705 is offline   Reply With Quote
Old 09-24-2013, 04:16 PM   #12
Doe_Rae_mi's Avatar
^ don't do that lol
Old 09-24-2013, 04:17 PM   #13
Mile high JDF's Avatar
+1^ it's a horrible way to lower your car.
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 09-24-2013, 04:20 PM   #14
lol I wouldn't do it but he says asap and well that's a very quick and easy way
Old 09-24-2013, 04:22 PM   #15
Doe_Rae_mi's Avatar
Lol true that
Old 09-24-2013, 04:24 PM   #16
Slow4V's Avatar
No wy
Old 09-24-2013, 05:37 PM   #17
Venomouz831's Avatar
Don't heat them. Just cut a coil on each one and if you want lower cut half more. By the way are those saleens side skirts
)02 Gt, Founder of WE2G
Old 09-25-2013, 09:40 AM   #18
Rich04's Avatar
Thanks alot, do the stock springs hold well cutt ? And yes they are
Old 09-25-2013, 10:13 AM   #19
If you cut a coil off each one they'll do ok. I'd properly lower it though. Mine has a basic Tokico shock/strut and cheap BBK spring lowering combo and it drives very well, no scraping and looks great. You're going to want CC plates though. Get MM ones.
01:11 PM
