Is it left hand or right hand thread - Mustang Evolution
Old 09-24-2013, 07:07 PM   #1
Ok mustang mechanics is this a left or right hand thread. Also what's the best way to get the bolt loosen. It spins every time I try to get it off and cannot think of a way to stop it.
Side note I'm replacing the passenger side tensioner and will be removing the timing cover. Will I need and special tools?
Thanks everyone
Patrickandberry is offline   Reply With Quote
Old 09-24-2013, 07:44 PM   #2
cliffyk's Avatar
I will assume you are referring to the crank pulley nut, if so it is right-hand thread. You need to use an impact wrench, or crank pulley holding tool to hold the pulley while you loosen the bolt.
Do not allow the engine to turn backwards a lot as there is a possibility of messing up the valve timing due to the timing chain "jumping"...
Old 09-24-2013, 08:05 PM   #3
i actually read on a forum just after i posted it, they said put the car in 5th gear and turn, Got it right off, now what the secret to getting it off? A giant pulley puller?
I have a smaller pulley puller but im having trouble getting the black pull off (one to the right of the rusted one)
any ideas?
Old 09-24-2013, 08:29 PM   #4
cliffyk's Avatar
You need a proper harmonic balancer puller
Old 09-24-2013, 08:33 PM   #5
I'll add that to the list.
How do you get this pulley off? The one I'm pointing a pencil at?
Old 09-24-2013, 09:00 PM   #6
cliffyk's Avatar
See above...
Old 09-24-2013, 09:42 PM   #7
Vmcgrath's Avatar
I believe you can rent this tool from the part store advance auto zone ect
Vmcgrath is offline   Reply With Quote
Old 09-24-2013, 10:51 PM   #8
Luna1994's Avatar
Region: Utah
Originally Posted by Patrickandberry View Post
Ok mustang mechanics is this a left or right hand thread. Also what's the best way to get the bolt loosen. It spins every time I try to get it off and cannot think of a way to stop it. Side note I'm replacing the passenger side tensioner and will be removing the timing cover. Will I need and special tools? Thanks everyone
i actually got it off with 2 flat head screwdrivers and a hammer.... The pulley it's self that is
Luna1994 is offline   Reply With Quote
Old 09-25-2013, 04:30 AM   #9
Slow4V's Avatar
You need a pulley remover
And a 1/2 gun or big breaker bar
11:44 AM
