Oil on spark plug - Mustang Evolution
Old 09-24-2013, 08:13 PM   #1
PBrown92's Avatar
Oil on spark plug
Changed the spark plugs in my 97 gt and noticed oil on the #7 spark plug. I'm not to familiar with these engines seeing as I just bought the car. Any suggestions on where the oil may be coming from.
1997 black GT
BBK CAI
SLP Loudmouth cat back
PBrown92 is offline   Reply With Quote
Old 09-24-2013, 08:40 PM   #2
Vmcgrath's Avatar
Oil is okay to be on spark plugs, what I was told
Vmcgrath is offline   Reply With Quote
Old 09-24-2013, 08:46 PM   #3
1996mustang's Avatar
Since when is oil ok on a spark plug? Imo oil in a spark plug is not a normal thing. Maybe the valve cover is leaking or maybe you have blow by in the cylinders. Oil on a spark plug doesnt mean the end of the world. However you may want to find the cause for it and repair it. Just my 2¢
Old 09-24-2013, 10:54 PM   #4
Redlsea's Avatar
I'm gonna say the oil is coming from the engine but that just my educated guess 😋 now on a more serious note it could be your valve seals or piston rings more un likely is a head gasket
Redlsea is offline   Reply With Quote
Old 09-24-2013, 11:15 PM   #5
Slow4V's Avatar
There should be nothing on spark plug at all
Old 09-24-2013, 11:23 PM   #6
yah that's not good bro, blow by
Mustangman705 is offline   Reply With Quote
Old 09-25-2013, 04:39 AM   #7
Vmcgrath's Avatar
My bad
Old 09-25-2013, 12:21 PM   #8
Your bad is saying "my bad". Also for thinking that oil is ok on a spark plug...
Old 09-25-2013, 12:25 PM   #9
take your oil cap off and check for white sludge on it.. if it does collant is getting in your engine and your ****ed
Old 09-25-2013, 01:54 PM   #10
Vmcgrath's Avatar
Not everybody can be wise and brilliant like you
I was told it was okay when I had oil on my plugs so I try to return the knowledge but turn out I was wrong
So again my bad
Just trying to help with the knowledge i though was right
Old 09-25-2013, 02:15 PM   #11
Is it on the tip or on the threads?
Old 09-25-2013, 02:29 PM   #12
Tyoung68's Avatar
Do a leak down test on it
Old 09-25-2013, 03:04 PM   #13
PBrown92's Avatar
How do you perform a leak down test?
1997 black GT
BBK CAI
Old 09-25-2013, 08:18 PM   #14
So again my bad
I'm not brilliant I just know basic automotive tech. Common knowledge is that oil in your combustion chambers is a very bad thing. Whoever told you that is an idiot.
Old 09-25-2013, 08:22 PM   #15
1lowGT's Avatar
There should not be anything besides air and fuel in there.
Old 09-25-2013, 08:51 PM   #16
Tyoung68's Avatar
[QUOTE="PBrown92;1807897"]How do you perform a leak down test?[/QUOTE
You have to get a tool and you take all of your spark plugs out and take a fuse of for the fuel pump. You screw in a gauge to the cylinders and they should all have about the same pressure i think i haven't do it in a while i know harbor freight sells the tool. Im sure you can find it on youtube
Old 09-26-2013, 10:22 PM   #17
Redlsea's Avatar
@ mustangman705 white sludge build up in the engine is not a fatal blow nor does it mean your getting coolant in your engine! It simply means you are doing short trips and the engine isn't getting up to temperature so condensation builds up on the surface of the inside of your engine like the inside of the valve covers and oil cap. It can be resolved by repeatedly running your engine at operating temperature . You should also change the oil after doing the full temperature cycles because the water and oil mix will create a highly caustic acid in your crankcase which can etch bearings, deteriorate your gaskets and wear your block. just figured I'd let ya know
Old 09-26-2013, 10:38 PM   #18
Slow4V's Avatar
Oil on plugs could just be valve stem seals need to be replaced
Old 09-27-2013, 05:40 AM   #19
Old 09-27-2013, 06:38 AM   #20
Slow4V's Avatar
Old 09-27-2013, 07:30 AM   #21
1lowGT's Avatar
Old 09-27-2013, 10:28 AM   #22
Old 09-27-2013, 10:32 AM   #23
Just wanted you to reread that. Valve stem is on your wheel, it's what you use to fill tires.
Old 09-27-2013, 10:34 AM   #24
Tyoung68's Avatar
Valve guides? Valve seats?
Old 09-27-2013, 10:45 AM   #25
If anyone here has ever rebuilt an engine you'd know he means these.
#facepalm
Old 09-27-2013, 10:54 AM   #26
Tyoung68's Avatar
Ha ohh those i forgot about them
Old 09-27-2013, 02:34 PM   #27
1lowGT's Avatar
I've been working on valves all this week. Was getting ready to use the grinder but that'll be next week.
Old 09-27-2013, 04:56 PM   #28
Slow4V's Avatar
H
Old 09-27-2013, 05:03 PM   #29
Slow4V's Avatar
Lol
Old 09-27-2013, 05:20 PM   #30
#facepalm
ACCESS DENIED!
What are you all talkin' about?
straybullitt is online now   Reply With Quote
Old 09-27-2013, 06:38 PM   #31
Slow4V's Avatar
Originally Posted by straybullitt View Post
ACCESS DENIED! What are you all talkin' about?
I said to replace the valve stem seals in the cylinder head , and someone replied that valve stem seals are on the tires and have nothing to do with spark plugs
Old 09-29-2013, 08:03 AM   #32
1lowGT's Avatar
Maybe he read it wrong or just wasn't clear enough.
Old 09-30-2013, 11:32 AM   #33
Nope, he probably has never had a motor apart and assumed he knew what he was talking about lol.
Old 09-30-2013, 12:11 PM   #34
Maybe i've never heard it called a valve stem seal. Still doesn't make sense to me.
Thanks for the assumption though.
Old 09-30-2013, 12:16 PM   #35
Valve seal, valve stem seal... same damn thing lol. Don't get all bent out of shape I'm just kidding around.
05:25 PM
