ticking from center of engine - Mustang Evolution
Old 09-24-2013, 11:12 PM   #1
so I don't think the ticking is coming from under the valve covers I listened closely and it seems to be from the middle of the motor... do youthink an exhaust manifold leak would cause that or am I looking at something else
Mustangman705 is offline   Reply With Quote
Old 09-24-2013, 11:55 PM   #2
04beautyGT's Avatar
I hate to mention this, but... I had some ticking a while back and since I didn't change my head gasket a chunk of gasket clogged the oil, and wrecked the lifters. A mechanic I know told me that the 4.6 2V were bad about doing that if the gaskets weren't changed every 100k or so miles ( I recommend letting a shop listen to it)
04beautyGT is offline   Reply With Quote
Old 09-24-2013, 11:56 PM   #3
Mfore33's Avatar
Only thing in middle is main bearings and crank. Possible oil pump going bad. Either way needs attention
Old 09-24-2013, 11:58 PM   #4
04beautyGT's Avatar
Actually I take it back, try not to drive it, my mechanic said I was lucky to save the engine
Old 09-27-2013, 10:52 AM   #5
jduckz5.0's Avatar
Fuel injectors tic also..get it checked out jic..
jduckz5.0 is offline   Reply With Quote
Old 09-27-2013, 11:05 AM   #6
I ran the engine and unplugged the injectors one at a time to see if any of them stopped the tick but nope
Old 09-27-2013, 11:10 AM   #7
jduckz5.0's Avatar
Ugh..u got a stethoscope? It's my favorite tool...lol
Old 09-27-2013, 11:19 AM   #8
lol nope but I have a long screw driver hahha what should I be putting it on to listen
Old 09-27-2013, 11:27 AM   #9
jduckz5.0's Avatar
Everything...tones will be deeper if its internal...injectors will be loud...go get a stethoscope from adv.,pep,etc.. trust me big difference and for $5...
Old 09-27-2013, 11:35 AM   #10
jduckz5.0's Avatar
Have u added zmax or Lucas??lots of posts on here about tic...if your intake was leaking it would be a vacuum more than tic..in center of motor its fuel inj. Unless a wire arching....
---------- Post added at 01:35 PM ---------- Previous post was at 01:32 PM ----------
Sound could travel from ex mani but you can narrow it down with the steth..
Old 09-27-2013, 11:37 AM   #11
yah but I don't know where to put the steath haha like rite on the injector itself?... I unplugged one at a time and the tick never stopped... does fuel injector cleaner actually work or is it just a money grabber additive.. would better gas help.. rite now I use mid grade 89
Old 09-27-2013, 11:57 AM   #12
jduckz5.0's Avatar
Inj. Tic no matter what u do...but cleaners work...I use seafoam in my car and have run it in lots of costumers cars...zmax is good too but pricey...if I were u n couldn't narrow it down.I'd check my plugs r tight,rubber is good on coils,run some lucas in oil,put some seafoam in tank,and check exh. Man for any black soot:...
Old 09-27-2013, 12:01 PM   #13
just changed my pugs and boots so all should be good and ticking was before I changed them as well...
had my exhaust checked at midas and they said there was no leaks.
removed my belt and ran the car tick was still there. replaced belt
pulled conector for injectors one at a time and tick was still there
had lucas in my oil previous oil change, still had tick. just had engine flushed and oil changed few days ago, no lucas but still tick
hmmm seafoam for injector cleaner?... I heard its a terrible idea to use.
Old 09-27-2013, 12:12 PM   #14
jduckz5.0's Avatar
Ive used it for years but use a different kind if u like...and you can run high octane for a couple tanks since u run 89 usually..
Old 09-27-2013, 12:34 PM   #15
I was told 89 is what I should be running that running the wrong fuel even premium is bad for your engine. it seemed to runn better with premium maybe I should fill up a tank again
Old 09-27-2013, 12:54 PM   #16
jduckz5.0's Avatar
If your running 89 u shouldn't go down to 87 but going up to 93 is not harmful...since u run 89 now when u put in 93 u will notice the it run stronger...
---------- Post added at 02:54 PM ---------- Previous post was at 02:51 PM ----------
Trust me when I was young like 20yrs ago I ran 93 then I put 87 to save money for a drive to Florida and I was pinging until I filled it back up with 93...
Old 09-27-2013, 01:04 PM   #17
jduckz5.0's Avatar
Is this the same noise from your other post???
---------- Post added at 03:04 PM ---------- Previous post was at 03:00 PM ----------
2 things I think from your tube vid....1. Check your egr tube...2. Check your PCv valve and tube..I'm thinking this is your problem...
Old 09-27-2013, 01:17 PM   #18
yes sir sure is. still trying to figure it out
Old 09-27-2013, 01:21 PM   #19
jduckz5.0's Avatar
Sounds like more of an exhaust tic leak so check egr and then the pcv tube might make that sound also...
Old 09-27-2013, 01:25 PM   #20
Pull the PCV valve, from the valve cover, with the vacuum line still attached, and the engine running, of course, and listen for any noise.
Old 09-27-2013, 01:35 PM   #21
I replaced the pcv valve and had the exhaust checked from a mechanic and he couldn't find a leak .... are you saying pull the pcv valve and listen to see if it stops or pull it and see if ic an hear the noise inside the valve cover
Old 09-27-2013, 01:39 PM   #22
jduckz5.0's Avatar
Egr tube Midas checked that???...on your video it sounds like its coming from there...but pull your pcv and you can hear if its internal better and check the pcv tube....
Old 09-27-2013, 01:41 PM   #23
Lol
Both.
Listen to the noise that the PCV makes AND anything else that you happen to hear.
You're definitely narrowing it down...
Old 09-27-2013, 01:43 PM   #24
oh no just the exhaust manifold and back ... s your saying the egr tube may be causing the tick?.... okay I will remove the pcv valve and listen inside the hole to see if it sounds to be coming from inside there... not sure what to do with the egr to be honest
Old 09-27-2013, 01:59 PM   #25
jduckz5.0's Avatar
The tube is hot so be careful but check it for leaks at the welds and where it screws into the bottom of egr...Midas would of found where it connects to converter but check tube as far down as you can...I have seen the tubes have lil pin dot holes in them that are hard to find cause the heat finds a weak spot in metal and pokes thru...so use a light and check it good before you get it hot...
---------- Post added at 03:59 PM ---------- Previous post was at 03:57 PM ----------
Check pcv tube also like straybullitt said...
08:40 AM
