Emblem Trouble. - Mustang Evolution
Old 09-25-2013, 03:07 PM   #1
Emblem Trouble.
Cant seem to find this emblem in my owners manual, any of you guys know it?
Potts is offline   Reply With Quote
Old 09-25-2013, 03:09 PM   #2
DaBluedude's Avatar
Coolant level / radiator fan issues. Haven't seen one on in a long time. Check to make sure Ur fan is spinning and you have enough coolant. Pretty sure. It was a coolant level issue for me.
2003 Mach 1
Old 09-25-2013, 03:12 PM   #3
H.Doofenshmirtz's Avatar
Region: Australia
Low Coolant warning
No work and no pony makes Doof a dull boy...
H.Doofenshmirtz is offline   Reply With Quote
Old 09-25-2013, 03:20 PM   #4
Ok Thanks guy!
Old 09-25-2013, 03:24 PM   #5
Mfore33's Avatar
Mine would go off but the coolant wasn't low the plug was corroded on the sensor
Old 09-25-2013, 03:28 PM   #6
Ya its come on for a minute and then it will go off and won't come back on for a while[COLOR="Silver"]
---------- Post added at 04:28 PM ---------- Previous post was at 04:28 PM ----------
Old 09-25-2013, 03:36 PM   #7
Region: Australia
Check your fluid levels first, if coolant isn't low then you likely have a dirty sensor. If you find yourself having to continually add coolant, a bigger issue is present.
Lets hope for a sensor eh?
Old 09-25-2013, 04:40 PM   #8
Roguestang's Avatar
I had this same issue, and I ended up disconnecting the sensor all together. The light went off, and hasn't come one since lol
1990 Mustang GT w/ Vortech V3
***resident gun idiot***
Old 09-25-2013, 06:01 PM   #9
its the sensor for your coolant, look down into where you fill your coolant and you will see the sensor, just fill it up till the sensor is in the coolant and it will go off.. I had the same issue
Mustangman705 is offline   Reply With Quote
05:55 PM
