NGK spark plug gap - Mustang Evolution
Old 09-25-2013, 11:10 PM   #1
Slow4V's Avatar
NGK spark plug gap
I got the TR55 NGK v power plugs , do I gap them to .054 ??
Old 09-25-2013, 11:57 PM   #2
yah, should come pre gapped just check them to make sure but ngk for my 2000 gt needed to be between .054 and .056
Mustangman705 is offline   Reply With Quote
Old 09-26-2013, 06:55 AM   #3
Slow4V's Avatar
Well I tried gaping them but they are already gapped to .060
Should I install them like that?
Or is there a way to close the gap down ?
Old 09-26-2013, 07:22 AM   #4
Slow4V's Avatar
Originally Posted by Slow4V View Post
Well I tried gaping them but they are already gapped to .060 Should I install them like that? Or is there a way to close the gap down ?
Never mind I just pushed down hard enough to close the tip,
Old 09-26-2013, 08:15 AM   #5
Make sure the gap is .054-.056 whatever you have to do. If you supercharge you'll usually have a tighter gap in the .030s somewhere. Gotta love a tight gap.
Old 09-26-2013, 09:15 AM   #6
Slow4V's Avatar
I think I found some oil on 1 spark plug on the drivers side , I can't really make it out .. It's just at the very bottom if you can see , a very small amount. What do you guys think?
It's not on the threads but right below them
It wasn't soaked , just had a small layer of some resedo
Old 09-26-2013, 09:15 AM   #7
Slow4V's Avatar
I think I found some oil on 1 spark plug on the drivers side , I can't really make it out .. It's just at the very bottom if you can see , a very small amount. What do you guys think? It's not on the threads but right below them It wasn't soaked , just had a small layer of some resedo
Old 09-26-2013, 10:41 AM   #8
I'd pull that plug again in a few thousand miles and take a look at it. The electrode looks fine though.
11:28 AM
