please someone respond - Mustang Evolution
Old 09-26-2013, 11:11 AM   #1
**** so I was changing my back plug on passenger side and the coolant hose came off and poored coolant down the spark plug hole... the plug is still in there and the cop is off... I tried to soak most the coolant up with paper towel but I can still see some down there. wtf d I do, please help.. tried compressed air and I can still see cooolant
Mustangman705 is offline   Reply With Quote
Old 09-26-2013, 11:18 AM   #2
Tyoung68's Avatar
Wait so you have coolant in one of your cylinders?
Old 09-26-2013, 11:19 AM   #3
the coolant hose came off and dumped coolant everywhere, and the spark plug hole filled up... the plug is still in but the hole was fulla coolant, I got most out with paper towel and air but I can still see some green at the bottom
Old 09-26-2013, 11:20 AM   #4
Tyoung68's Avatar
Oh wait i see re read it just a turkey baster and suck it up or a shop vac
---------- Post added at 10:20 AM ---------- Previous post was at 10:19 AM ----------
How much?
Old 09-26-2013, 11:22 AM   #5
filledthe hole rite up, its just some at the bottom. I can see most the plug I tried putting paper town down and cant get the rest
---------- Post added at 11:22 AM ---------- Previous post was at 11:22 AM ----------
will I **** my engine up if I put the cop back on and start the car
Old 09-26-2013, 11:43 AM   #6
Grrrr....'s Avatar
Soak as much up with a paper towel you can. Try putting a ppr towl down there and use somethin pointy like a screw driver to poke it down around the plug. Don't take the plug out. I would put the wire back on and leave the boot cracked open so the rest can evaporate out. Shouldn't hurt anything.
Grrrr.... is offline   Reply With Quote
Old 09-26-2013, 11:48 AM   #7
Tyoung68's Avatar
How much are we talking? Can you take a picture?
Old 09-26-2013, 11:59 AM   #8
pretty sure I got almost all of it with qtips on a screw driver lol I have to go to work soon haha ahhh so I changed the boot on my cop and im ready to put it back together.. I was guna change the plug but I will wait obv now.. if its not 100% dry is something bad guna happen... could I have ruined the plug by the top being soaked
Old 09-26-2013, 11:59 AM   #9
Tyoung68's Avatar
No you should be fine
Old 09-26-2013, 12:04 PM   #10
sure hope so, what do you think the chances electrical stuff got soaked and the car wont turn on... haven't tried yet guna give it about an hour to air dry before I try and start it
Old 09-26-2013, 12:06 PM   #11
Tyoung68's Avatar
Uhh idk how much came out?
Old 09-26-2013, 12:15 PM   #12
bigmac3's Avatar
[QUOTE=Mustangman705;1808526...poored coolant down the spark plug hole... [/QUOTE]
As long as you never took the plug out, continue with life like it never happened. It should run just fine and will eventually evaporate.
Frank
1989 Blue LX Hatchback
2001 Red SVT Cobra Convertible (Phoenix)
2002 Black/Red GT (Ginger)
2011 Red Candy Metallic V6 (Manfred)
2016 Magnetic Metallic GT (Susie II)
bigmac3 is offline   Reply With Quote
Old 09-26-2013, 12:20 PM   #13
a lot kinda, like 4 inches outa my coolant tank is emptied... I have a jug of coolant so im going t top it back off but fuuu hahaha I shoulda just paid a mechanic to do all the work, I always try and do things myself and I end up running into issues
Old 09-26-2013, 12:33 PM   #14
Skulls98GT's Avatar
If you got most of it out you shouldn't have any major problems. As your motor warms up the rest will evaporate. I had this same problem when I washed my engine bay. I got water in a couple of my plug wells. I had some misfire here and there, but not enough to trip a CEL. I then did my plugs and wires just to be safe. They needed it anyway.
Skulls98GT is offline   Reply With Quote
Old 09-26-2013, 12:53 PM   #15
THANKS TO EVERYONE WHO RESPONDED... put the cop back on and she fired rite up. lots of smoke off parts of the engine but after letting it run for 5 mins no more smoke. still has the tick haha really wish I could figure out what it is, even if I have to pay to get it fixed id love to get my engine running like new
Old 09-26-2013, 12:56 PM   #16
Soak it up, let it dry, stop being completely and totally unnecessarily obsessed with finding a tick in your motor since they ALL tick and its just a fact of life. You should hear my wife's car, its a 2.0 Honda 4 banger that sounds like a sewing machine and its totally normal for that engine. If you keep messing with it you're going to break something as you almost found out today.
Old 09-26-2013, 01:07 PM   #17
hahaha scotty you DO know! HAHA ... I think its the fact that my buddy has a crown vic witch is basically the same engine and sounds so smooth compared to mine that I just want to figure out whats wrong with mine! ... and altho my car is old I would like to maintain it and have it run like new rather then rat bag it till its a pos
Old 09-26-2013, 01:17 PM   #18
although I spent the first 3 hours of my day ****ing up and fixing an issue I should have never had its okay that it happened. that hose was ready to fall off obviously, it had released from the clamp and was just barely holding on.. rather it happen today then drivin down the road and running out of coolant!... the hose that comes out of the fire wall on the passenger side rite above the last cop
Old 09-26-2013, 03:24 PM   #19
You were lucky it happened in your driveway.
I still think the "tick" that you're hearing is injector noise. Pull the connectors off, one at a time, and listen, to see if the ticking gets any quieter.
The belt trick is good, but, remember that neither the water pump nor the alternator will be working so do it on a COLD engine and don't run it for very long...
Old 09-26-2013, 11:23 PM   #20
Wow, sounds like a bad time changing spark plugs.
Old 09-27-2013, 12:27 AM   #21
hahah definitely... its that last one on the passenger side, I cant seem to get my extension on that angle with that hose in the way, and the hose is apparently a coolant line so im sol
Old 09-27-2013, 06:06 AM   #22
That's your heater core hose, there should be 2 coming out of the firewall. Not going to hurt anything if you pull the hoses off and put a pan underneath to catch the coolant that comes out before it stops. Just make sure you burp your coolant system whenever you have it open to the air like you did by accident yesterday.
Old 09-27-2013, 09:40 AM   #23
all I did was add more coolant and close the cap and continued to drive, so far so good tho. was that a bad idea
Old 09-27-2013, 10:49 AM   #24
look up how to burp your coolant system on the google or youtube. Why does nobody know wtf burping the coolant system is? That's like auto 101... You are like the 10th person I've had to tell this to on this forum lol.
Old 09-27-2013, 11:07 AM   #25
lol I know how to do it just leave the cap off and run the engine and fill till its at the line settled but I just neglected to do that and now my coolant is like full to the cap ahha
Old 09-27-2013, 06:01 PM   #26
Region: Iowa
The tick noise can be many things , cracked exhaust manifold, exhaust gasket missing a small piece , exhaust donut leaking , injectors , rockers , rods
Iowaboy13 is offline   Reply With Quote
02:34 PM
