Rear end - Mustang Evolution
Old 09-27-2013, 02:16 PM   #1
98mustang_gt's Avatar
Rear end
I changed my pinion seal 2 months ago because my mechanic said it was leaking real bad. I noticed when I lifted my car up that It was leaking again. Any idea why it would start leaking again?
98mustang_gt is offline   Reply With Quote
Old 09-27-2013, 02:30 PM   #2
Venomouz831's Avatar
Was the gasket properly installed? Tightened everything good?
)02 Gt, Founder of WE2G
Old 09-27-2013, 02:56 PM   #3
That could be the issue. I hardly drive the car and its already leaking again.
Old 09-27-2013, 03:03 PM   #4
Check the vent and the vent hose, on top of the axle tube, to make sure that it isn't clogged up.
Pressure can build up and cause leaks.
Old 09-27-2013, 03:24 PM   #5
I'm taking it to my mechanic on Tuesday. Is it okay if I drive it for about 20 miles like that?
Old 09-27-2013, 03:29 PM   #6
Yes. It should be fine. Usually pinion seal leaks are very slow...
Old 09-27-2013, 03:30 PM   #7
Site Sponsor
Sponsor
AMWill's Avatar
Assuming your vent tube isn't clogged, it sounds like the crush washer was crushed too tight. I've seen this cause a light leak quite a few times. I'm betting a new crush washer will fix everything up!
How bad is the leak? very slow drips or a spill? If it's dripping very slowly, I wouldn't worry about the 20min drive to your mechanic. However, if it's dripping fast, it may be a good idea to tow it.
Shane
Toll Free: 866.727.1266
Free Same-Day Shipping!
Old 09-27-2013, 03:34 PM   #8
Shane
It's just a slow leak.
Old 09-27-2013, 03:54 PM   #9
You're good then. Drive it to the shop
Old 09-27-2013, 04:00 PM   #10
Okay thanks guys
Old 09-30-2013, 02:00 PM   #11
Site Sponsor
Sponsor
AMWill's Avatar
That's good, you shouldn't have any issues driving the car than. Did you get a chance to take the car over to your mechanic this weekend? Any updates?
Shane
Old 09-30-2013, 02:41 PM   #12
Shane
My off day is tomorrow so I'm taking it then. Ill give you an update then.
03:34 PM
