P0783 - Mustang Evolution
Old 09-28-2013, 12:47 PM   #1
mustangmar2001's Avatar
P0783
Just got my car back from the shop and it's throwing these two codes up... P0783 and p1000
mustangmar2001 is offline   Reply With Quote
Old 09-28-2013, 02:29 PM   #2
P1000 is that your sensors were reset. Battery disconnected or codes cleared. P0783 is a tranny code....shift malfunction from 3 to 4. Possibly a bad shift solenoid
UDBigJim is offline   Reply With Quote
Old 09-28-2013, 02:33 PM   #3
cliffyk's Avatar
Are you certain P0783 is the code? That is not one that is listed as being supported on the GT...
Old 09-28-2013, 03:15 PM   #4
I'm positive.. I took my tuner and put the car back to stock and the o/d light hasn't flashed on and off anymore. Now it's reading this P0430 code. I had new coil pack and spark plugs put in and it's been acting strange since i got the car back.
Old 09-28-2013, 03:25 PM   #5
P430 is not 783
Old 09-28-2013, 03:43 PM   #6
9tee7pony's Avatar
My car has been throwing the p0430 code for awhile now. Essentially it is just the cat not working at the intended effentiency. I've just been ignoring it, there doesn't seem to be that it causes other than a strong exhaust smell in a garage.
9tee7pony is offline   Reply With Quote
Old 09-28-2013, 03:46 PM   #7
Originally Posted by UDBigJim View Post
P430 is not 783
Lol, I know that.. I don't know why it changed
Old 09-28-2013, 08:08 PM   #8
1996mustang's Avatar
P0783 is a shift malfunction between 3-4. Could be a bad solenoid or worst case u need a new tranny or rebuild of your auto tranny.
It comes and goes sedomly im sure. Any info like you feel it slip or anything while in drive?
Old 09-28-2013, 08:28 PM   #9
Originally Posted by 1996mustang View Post
P0783 is a shift malfunction between 3-4. Could be a bad solenoid or worst case u need a new tranny or rebuild of your auto tranny. It comes and goes sedomly im sure. Any info like you feel it slip or anything while in drive?
When the o/d light was flashing, it was shifting hard at times. I'll take it to ford if it starts acting up again and see what can they do.
Old 09-28-2013, 08:49 PM   #10
I have a question. I'm fairly new with this bama tuner and was curious about something. Well, I put the custom tune on the car before it was sent to the garage to have work done.. Would the updates to the car mess up my current tune? Sorry if anyone thinks this question is stupid.
Old 09-29-2013, 10:44 AM   #11
Yes i would get it retuned if possible so u can maximize it.
Old 09-29-2013, 11:17 AM   #12
I appreciate your reply back.. I'll do that.
02:20 PM
