Question - Mustang Evolution
Old 09-30-2013, 08:25 PM   #1
mustangmar2001's Avatar
Question
What does it mean when anti freeze leaks from that?
mustangmar2001 is offline   Reply With Quote
Old 09-30-2013, 08:31 PM   #2
Seegin's Avatar
The O ring is bad or in the wrong spot
Seegin is offline   Reply With Quote
Old 09-30-2013, 09:04 PM   #3
sean03gt's Avatar
If it looks like the the anti freeze is leaking from the intake it could possibly be. A cracked intake (that's were mine was leaking from and found out the intake was cracked). But if it looks like its leaking from the housing possibly the housing could cracked
sean03gt is offline   Reply With Quote
Old 09-30-2013, 09:07 PM   #4
dylanmullins's Avatar
If nothing is cracked it could be just the o ring for the thermostat.
dylanmullins is offline   Reply With Quote
Old 09-30-2013, 09:08 PM   #5
is it coming from the black plastic manifold... does rite at the front.. if so im going to guess yours is made of all composite plastic.. you will have a big job ahead of you but you can but a replacement one with an aluminum cross over like I did to prevent this from happening again ... don't run the car until its fixed! ...
Mustangman705 is offline   Reply With Quote
Old 09-30-2013, 09:19 PM   #6
If you replace the intake I would get a typhoon intake. They are sick. And as for a lot of work ahead of you. I can put an intake on a 2v 4.6 in around 30 minutes?
Old 09-30-2013, 09:29 PM   #7
lol well for you might only take half hour.. now that I have done it I could probably do it fairly quickly as well but you will need to have an idea what you are doing... make sure you remove the pressure from the fuel rails...
Old 09-30-2013, 09:38 PM   #8
I guess being a tech is being a cheater huh haha
Old 09-30-2013, 09:43 PM   #9
hahaha not saying anything bad but its not as simple as you make it seem... it isn't hard either but just gotta have patience, know what your doing with the fuel rail and torque everything to spec and the rest is just remembering how you took it apart
02:39 PM
