idle - Mustang Evolution
Old 10-01-2013, 10:57 AM   #1
idle
ok so my car ides at about 1500 but when I have the air on, heat or air conditioner it jumps all around ... is that normal
Mustangman705 is offline   Reply With Quote
Old 10-01-2013, 11:05 AM   #2
1lowGT's Avatar
Prepare for a new engine. Just playing
Old 10-01-2013, 11:08 AM   #3
hahhaa im thinking a vacuum line maybe but I checked what I could see. any ideas
Old 10-01-2013, 11:43 AM   #4
Doubledeee99's Avatar
I had a piece replaced that had my rpms go down about 1000. Not sure what it's called though but it was cheap and small, that's what I did to fix it. But I was searching the forum and you can find other threads about people cars idling loud. Might wanna look at those as well.
Doubledeee99 is offline   Reply With Quote
Old 10-01-2013, 02:10 PM   #5
1lowGT's Avatar
Yeah search some other threads and see if you can find your problem that someone else has had.
Old 10-01-2013, 05:01 PM   #6
AgentOrange's Avatar
Start by cleaning IAC, MAF, and throttle body.
AgentOrange is offline   Reply With Quote
Old 10-01-2013, 05:26 PM   #7
Doe_Rae_mi's Avatar
+1
Old 10-02-2013, 08:39 AM   #8
jduckz5.0's Avatar
Your car is ticking and idling too high??? From all your threads it seems you have a problem internally or the info your giving us is inadequate or you haven't done any of the suggestions given...too many possibilities of problems with your car at this point...take it to a known mustang mechanic not Joe shmo mechanic and find your problem or problems...
jduckz5.0 is offline   Reply With Quote
Old 10-02-2013, 10:44 AM   #9
it runs great but has a tick, but apparently almost everyone on this forum has a tick... when I use the air or heat the idle bounces around when im stopped . not sure if that's normal... with no air or heat on it idles consistently in the same spot
Old 10-02-2013, 12:06 PM   #10
04__gt's Avatar
Do you have exhaust simulator 02 censors on it? One could be bad that's what made mine start acting crazy
04__gt is offline   Reply With Quote
Old 10-02-2013, 12:16 PM   #11
jduckz5.0's Avatar
1500 is a high idle...
Old 10-02-2013, 12:35 PM   #12
Roguestang's Avatar
The high idle is probably caused by your a/c compressor cycling on and off. Could be low on refrigerant, or your compressor is on its way out.
1990 Mustang GT w/ Vortech V3
***resident gun idiot***
Old 10-02-2013, 12:43 PM   #13
jduckz5.0's Avatar
He said its 1500 idle then he turns on heat/ ac and it idled crazy...let's put this together from his threads....1. Engine ticks....2.idles at 1500 rpm....3.idle jumps around after ac/ heat is turned on...this car has an internal issue or has a few different issues...practically impossible to diagnose online....
Old 10-02-2013, 12:48 PM   #14
Roguestang's Avatar
Oh ok. I re read it. Sounds like a complete mess.....lol
Old 10-02-2013, 04:28 PM   #15
haha re read that my self and questioned it so jumped in the car... when I turn it on it revs at 1k then settles between 5-1k when I turn on any air it jumps around between 5-1k doesn't settle... should it be jumping like that or should it settle at an rpm like idle .... there is my edit
---------- Post added at 04:28 PM ---------- Previous post was at 04:26 PM ----------
also jw roguestang when you lift your hood is your engine silent or do you yourself have any tick
Old 10-02-2013, 05:02 PM   #16
Roguestang's Avatar
Well yes lol, there is a slight tick (really more of a clicking sound), but its my injectors. And your idle should settle down, and not jump around. I'd start by looking at the compressor and go from there.
Old 10-02-2013, 05:06 PM   #17
how are you sure its your injectors... I tried unplugging mine one at a time to see if it stopped but unless its more then one I don't think so ... hhaha I think everyone except jduckz5.0 is livin with some kinda tick... his car must be mint
Old 10-02-2013, 05:28 PM   #18
Roguestang's Avatar
Well I used a stethoscope with an open tube on the end. When I put the end up to the injector, I could deduce the noise came from them. Its really not something I would be upset or concerned about. If the sound gets louder, or you notice losses in power, then you would want to get it looked at. But I wouldn't waste your time on it. Every car has its qwirks and personality, and as Mustang enthusiasts its up to us to brace them. Lol
Old 10-02-2013, 05:33 PM   #19
so you put the end rite on the injector. like on the orange part or whatever color your injector is... would a long as screw driver basically do the same thing
Old 10-02-2013, 05:44 PM   #20
Roguestang's Avatar
Screwdriver might work as well. But basically you just move it around the engine bay until you hear the noise get louder/ isolated. When it got close to the injector, I could identify that's where it came from, since it got louder.
Old 10-02-2013, 05:46 PM   #21
irishn8's Avatar
Yes a screw driver to the ear works fine. Is the tick regular or erratic? It happens only with the a/c on? Try unplugging the connector to the ac compressor and see what happens. Is the air as cold as u remember it?
Old 10-02-2013, 05:52 PM   #22
but your injector should tick if you listen to it. you should hear it pulsating
---------- Post added at 05:52 PM ---------- Previous post was at 05:50 PM ----------
its just a tick its not really loud or hard sounding just wanted to figure it out and eliminate it. trying to take care of my car not just live with the problems ...
no happens all the time and does not get louder or faster when I rev the car up
Old 10-02-2013, 05:54 PM   #23
irishn8's Avatar
Injector tick isn't usually heard without a stethoscope.
Old 10-02-2013, 05:58 PM   #24
Roguestang's Avatar
Well they aren't deafening, but all the 4.6's that I've worked on, or people in know that own a vehicle with one, say they can hear it too; and that's by ear.
Old 10-02-2013, 06:13 PM   #25
an injector will tick if you use the scope... if it doesn't tick then it isn't working .. do all your injectors tick the same or is it more erratic then others
Old 10-02-2013, 07:09 PM   #26
jduckz5.0's Avatar
Listening to your video...it has a loud tick...seems more than injectors...
Old 10-02-2013, 07:20 PM   #27
oh yah i don't think its injectors because i unplugged one at a time while it was running and i still got the tick .. its not crazy loud tho as you have to open the hood to hear it.. i brought it to 2 different mechanics who just brushed it off as a normal 13 year old car, as well as the mechanic at work who said just keep doing my oil changes and it should run forever haha kinda wish someone would have had an answer for me tho
Old 10-02-2013, 07:43 PM   #28
Mfore33's Avatar
Timing chain slap from worn chain guides cause they are plastic
Old 10-02-2013, 08:06 PM   #29
thought about that
Old 10-02-2013, 08:48 PM   #30
Mfore33's Avatar
If you plan on opening up the front of the motor do a timing chain upgrade and guides also new water pump while your there. Take care of everything you can that's related to the front of the motor.
Old 10-02-2013, 08:58 PM   #31
when I listen to it seems like its coming from the passenger side coil closest to the fire wall, or something in that area, maybe closer to the middle of the motor, but that's just the intake so im not sure, sound echos under there... would a bad cop do that or would it just misfire completely and throw a code
Old 10-03-2013, 12:02 AM   #32
irishn8's Avatar
If there is a gap then it will arch and cause a tick but that would increase in speed when u rev
04:46 AM
