Pwr windows - Mustang Evolution
Old 10-01-2013, 11:38 AM   #1
theweekday's Avatar
Pwr windows
So my windows won't go down or up at all.
I tested my motors and the they went up n down fine but when I hit the switch nothing happens, I snagged some used switches but the same thing. Can someone help me please?
theweekday is offline   Reply With Quote
Old 10-01-2013, 01:48 PM   #2
theweekday's Avatar
Bump
Old 10-01-2013, 03:41 PM   #3
Coltonhess's Avatar
The black tube between your door. Squeeze that a couple times and it could work. I talked to a mechanic about it before when I had a similar problem. You also can check to see if you are getting power to your switches. There will be 2 that make power no matter which way you push the switch. 1 that makes power when you push up and 1 when you push down. At first it was confusing. I ended up having to replace my driver side motor and then both my windows worked after that. It's a fickle thing with these window electronics
Coltonhess is offline   Reply With Quote
01:51 PM
