clutch adjusting/ tb noise help please - Mustang Evolution
Old 10-01-2013, 11:27 PM   #1
so i recently replaced the clutch tb, pb, and all that stuff in there with the exedy stage two stuff for my 04 gt. its been about 2500 miles since that and now my tb is making the same noise it made before it went completely out, clutch feels ok sometimes and then sometimes it feels too soft.... in the very beggining i didnt have that problem at all. anyways when im driving its a pretty faint sound and goes away when i push the clutch in to right before it starts to disengage, anything before that it makes the noise, at stop lights and such too while im in neutral.
anyways i called exedy and they said it could be a stretched cable? im not very familar with clutch cables or anything but ive read that they self adjust and that there are adjusting cables as well for adjusting at the clutch fork. so what would you guys reccomend that i do?
brandon151 is offline   Reply With Quote
Old 10-02-2013, 12:22 AM   #2
Slow4V's Avatar
Originally Posted by brandon151 View Post
so i recently replaced the clutch tb, pb, and all that stuff in there with the exedy stage two stuff for my 04 gt. its been about 2500 miles since that and now my tb is making the same noise it made before it went completely out, clutch feels ok sometimes and then sometimes it feels too soft.... in the very beggining i didnt have that problem at all. anyways when im driving its a pretty faint sound and goes away when i push the clutch in to right before it starts to disengage, anything before that it makes the noise, at stop lights and such too while im in neutral. anyways i called exedy and they said it could be a stretched cable? im not very familar with clutch cables or anything but ive read that they self adjust and that there are adjusting cables as well for adjusting at the clutch fork. so what would you guys reccomend that i do?
Did you use the exedy TOB ?
And did you lube it up real good ? / Fork too
Old 10-02-2013, 12:38 AM   #3
yes and yes, i lubed the shaft on the tranny, the ball where the fork goes but not the fork itself... ive read on some other sites that its somewhat normal for the noise to be there but i dont really believe that.. car has 90500 miles by the way.
Old 10-02-2013, 05:20 AM   #4
Slow4V's Avatar
That's were you messed up, never use aftermarket TOBs always replace with ford OEM or better ford racing professional products they are the best and won't make noise
Old 10-02-2013, 07:01 AM   #5
Agreed, use the FRPP one. I've done multiple King Cobra clutches that come with the FRPP TOBs and NEVER had an issue.
Old 10-02-2013, 11:48 AM   #6
damn.. haha i was gonna buy the king cobra clutch but literally every single vendor had them on back order for like a month and i needed my car back.
anyways i cant really pull the tranny again anytime soon to put a frpp one in there do you think ill be ok running it for now?
05:07 PM
