smoke from 1 pipe - Mustang Evolution
Old 10-02-2013, 05:18 PM   #1
Kevo91's Avatar
Region: Utah
smoke from 1 pipe
So I just changed the lower intake on my 98 gt because it was cracked. Anyway new intake is in, no leaks and the car is cooling fine but im getting some blue-ish smoke out of my driver side tailpipe. Its got a stock H pipe, consistantly smokes a little at idle and I get a big cloud of it when I stab the gas
---------- Post added at 05:18 PM ---------- Previous post was at 05:16 PM ----------
Also Im getting some vibration about 2500-3000 rpm, plugs are all new and everything is plugged in good
Kevo91 is offline   Reply With Quote
Old 10-02-2013, 06:30 PM   #2
1996mustang's Avatar
Did you make sure no oil or coolant fell in the intake entrance? Could be the initial start have you driven it yet or is this the first time you started it.
Old 10-02-2013, 11:28 PM   #3
Kevo91's Avatar
Region: Utah
Nothing got down in there. It was the first start but it was running for at least a half hour
Old 10-03-2013, 06:34 AM   #4
Slow4V's Avatar
Originally Posted by Kevo91 View Post
So I just changed the lower intake on my 98 gt because it was cracked. Anyway new intake is in, no leaks and the car is cooling fine but im getting some blue-ish smoke out of my driver side tailpipe. Its got a stock H pipe, consistantly smokes a little at idle and I get a big cloud of it when I stab the gas ---------- Post added at 05:18 PM ---------- Previous post was at 05:16 PM ---------- Also Im getting some vibration about 2500-3000 rpm, plugs are all new and everything is plugged in good
Sounds like you valve guides or rings are gone, blue smoke indicates oil burning on that side of the head
« idle | Sagging door »
12:38 AM
