Code P1127 - Mustang Evolution
Old 10-03-2013, 01:32 PM   #1
1lowGT's Avatar
Code P1127
I got a misfire and got codes p1000 an p1127
Old 10-03-2013, 01:41 PM   #2
MidnightBlueGT's Avatar
P1000 is the drive cycle isnt complete like the battery was disconnected. Cant remember the other code
Old 10-03-2013, 01:45 PM   #3
1lowGT's Avatar
My battery is connected thiugh
Old 10-03-2013, 01:58 PM   #4
Thats how mine was but it was because my o2's were turned off
Old 10-03-2013, 02:04 PM   #5
1lowGT's Avatar
I see. Well I still need to find what causing my misfire.
Old 10-03-2013, 02:50 PM   #6
Innova - DTC Library - Diagnostics Made Easy
P1127 Ford Exhaust Temperature Out of Range, O2 Sensor Tests Not Completed
Old 10-03-2013, 04:48 PM   #7
1lowGT's Avatar
So will this cause a misfire? How do I fix it?
Old 10-03-2013, 05:00 PM   #8
I THINK that a misfire will cause the 1157 code
Old 10-03-2013, 07:58 PM   #9
1lowGT's Avatar
I only had p1127 and p1000
Old 10-03-2013, 08:09 PM   #10
i meant to say 1127 & Your first post says you had a misfire tho
Old 10-03-2013, 09:26 PM   #11
1lowGT's Avatar
Oh. Well yeah I have a misfire and those are the codes. Idk how to fix this.
Old 10-03-2013, 09:53 PM   #12
Do you know which cylinder is misfiring?
Old 10-04-2013, 11:20 AM   #13
1lowGT's Avatar
Nope. Just gave me the codes and that's all.
Old 10-04-2013, 11:28 AM   #14
if you found out which one is misfiring then you could clear the codes and swap some coils around and if the misfire followed the coil then its probably bad coil. if the misfire stayed the same then more than likely bad plug but im not sure what to do right now. bad gas can cause a misfire too so first thing you might do is clear the engine codes & run a can of seafoam through the tank & maybe the vacuum line off the brake booster & see if that clears it up??
Old 10-04-2013, 11:41 AM   #15
1lowGT's Avatar
I've been running 93 at the best station in town and nothing but that for prop ably 8 months so it's not gas. I'll try seafoam. But if it was a bad coil wouldn't it miss really bad and only run on 7 cylinders? Cuz it only misses at low rpms and low load while driving. Wot no problems.
Old 10-04-2013, 12:11 PM   #16
im just throwing suggestions bro lol I don't KNOW anything much but it could be signs of it trying to go out. could be a cracked plug or a broken boot on one of the coils but apparently a coil is either good or bad
Old 10-04-2013, 06:41 PM   #17
1lowGT's Avatar
I might. Get a new coil and switch it out on every one of them and see if it fixes one.
Old 10-04-2013, 08:45 PM   #18
Sounds time consuming bro
Old 10-05-2013, 01:10 PM   #19
1996mustang's Avatar
does it happen on idle and low rpms only? had a friend with the same problem sorta and it turned out to be iac, and didnt throw codes for it.... just my $0.02
Old 10-06-2013, 08:04 AM   #20
1lowGT's Avatar
Yes. Or even under a low load never heavy. Could I just clean the iac or do I have to replace it
Old 10-06-2013, 10:40 AM   #21
My recommendations are attempt to clean it to see if it improves but other than that if u can id change it
Old 10-06-2013, 03:53 PM   #22
1lowGT's Avatar
Where's it at and how much they cost?
Old 10-06-2013, 09:50 PM   #23
Its on the plenum and roughly $45-60 at a local autoparts.
Old 10-07-2013, 08:00 AM   #24
1lowGT's Avatar
Okay well yesterday I attempted to check my injectors with a multimeter and didn't really find much. But I started it up and it was missing worse than it was before. So I checked and pushed in all the injectors and the passenger side far back one was messed up. I wiggled it around and It smoothed out the idle like it was before. Is it possible that it has bad connection? I still have to small miss at idle though.
Old 10-07-2013, 02:02 PM   #25
Its quite possible that it might have a baf connection. Id check the pins on it to make sure and also check the wires on it if messing with it smoothed out the idle id say u found one cause.
Old 10-07-2013, 03:00 PM   #26
1lowGT's Avatar
Like it's always missed. But then it was missing worse then I messed with it and it cleared it back to the original miss
Old 10-07-2013, 07:28 PM   #27
Have u cleaned/changed the idle air contol valve yet?
---------- Post added at 09:28 PM ---------- Previous post was at 09:27 PM ----------
It possible it could be a vacuum leak as well. Get a can of carb cleaner and lightly spray over hoses and vavuum lines. Listen for a raise in the rpms whilr u do it so you can pinpoint a leak if possible
Old 10-07-2013, 08:24 PM   #28
1lowGT's Avatar
Haven't yet. Don't have time. I'll try that. What lines do I check exactly?
Old 10-07-2013, 08:40 PM   #29
Any vacuum lines. By the plenum to the intake to the evap canister pretty much any line thats a vacuum line
12:23 PM
