Sagging door - Mustang Evolution
Old 10-03-2013, 04:22 PM   #1
Sagging door
so my drivers side door kinda sags, some times you need to kinda lift it up when you close it... is there an easy way to fix this or will I need new door pins.. anyone have experience with this
Mustangman705 is offline   Reply With Quote
Old 10-03-2013, 04:32 PM   #2
Venomouz831's Avatar
Tighten up the bolts on the hinge, see if the helps or loosen the bottom ones a bit and tighten up the top
)02 Gt, Founder of WE2G
Old 10-03-2013, 04:34 PM   #3
Replacing the hinge assemblies will be your easiest fix.
02:41 PM
