HELP PLEASE.. Working on car now - Mustang Evolution
Old 10-04-2013, 06:59 PM   #1
slow281
sixpac's Avatar
Region: Nebraska
Just got done swapping to a triple hook quadrent but now my cruise won't work.. WTF did I do?? It worked before..
Need more Horsepower? Add a sticker. Contact me for vinyl stickers pre-made and custom!
Stick on Horsepower <- Click Here and like my Page!
2001 GT - True Blue
2003 V6 - Zinc Yellow
1990 LX 2.3 - project
sixpac is offline   Reply With Quote
Old 10-04-2013, 07:28 PM   #2
slow281
sixpac's Avatar
Region: Nebraska
Anyone need help bad
2001 GT - True Blue
Old 10-04-2013, 07:33 PM   #3
Tyoung68's Avatar
You need three things to start a car. Fuel, air and spark. Your getting air so your down to two now go from there and work back
Old 10-04-2013, 07:50 PM   #4
slow281
sixpac's Avatar
Region: Nebraska
Confused... My cruise isn't working....??
2001 GT - True Blue
Old 10-04-2013, 07:53 PM   #5
Well one of the ways to turn off cruise is the clutch switch. Check too see if it is pressed or tripped.
Old 10-04-2013, 07:54 PM   #6
slow281
sixpac's Avatar
Region: Nebraska
Thanks this is probably what I need.. What makes that happen??
2001 GT - True Blue
Old 10-04-2013, 07:56 PM   #7
Tyoung68's Avatar
Ha oh i thought you meant your car would start
Old 10-04-2013, 08:07 PM   #8
slow281
sixpac's Avatar
Region: Nebraska
Lol nbd I hope that's my only problem..
2001 GT - True Blue
Old 10-04-2013, 09:23 PM   #9
Gotta be your clutch switch. Unless you bumped the cruise motor/cable somehow if you were in the engine bay messing with the clutch cable at all.
Old 10-04-2013, 09:28 PM   #10
slow281
sixpac's Avatar
Region: Nebraska
Maybe.. Ware is the clutch switch at..
2001 GT - True Blue
Old 10-04-2013, 09:29 PM   #11
Under the dash right by the pedal. There should be a linkage going right to it.
Old 10-05-2013, 08:48 AM   #12
slow281
sixpac's Avatar
Region: Nebraska
Figured it out, my new quadrent wasn't thick enough to push the switch down.. All fixed now!
2001 GT - True Blue
Old 10-05-2013, 04:12 PM   #13
Not thick enough... we've all been there...
Old 10-05-2013, 04:13 PM   #14
slow281
sixpac's Avatar
Region: Nebraska
Your humor.. Lmao!
2001 GT - True Blue
Old 10-05-2013, 04:13 PM   #15
MidnightBlueGT's Avatar
There are surgeries to fix that
Old 10-05-2013, 04:23 PM   #16
Nah, I just married a 100lb woman.
Old 10-05-2013, 07:38 PM   #17
AgentOrange's Avatar
Winner.
AgentOrange is offline   Reply With Quote
Old 10-05-2013, 07:39 PM   #18
slow281
sixpac's Avatar
Region: Nebraska
Originally Posted by AgentOrange View Post
Winner.
Haha me too! But agent every time I read your name I aware it says Anal orange
2001 GT - True Blue
Old 10-05-2013, 07:40 PM   #19
That just means you like butthole. Only thing the two words have in common is the first letter
Old 10-05-2013, 07:43 PM   #20
02GTvert's Avatar
Well that escalated quickly..
02GTvert is offline   Reply With Quote
Old 10-05-2013, 08:00 PM   #21
They say you associate words and phrases by the first and last letters no matter what it actually says. Like the brand FCUK (French Connection UK) for example.
Either that or his anus is the diameter of an orange... Could be handy for smuggling drugs.
Old 10-05-2013, 08:07 PM   #22
slow281
sixpac's Avatar
Region: Nebraska
They say you associate words and phrases by the first and last letters no matter what it actually says. Like the brand FCUK (French Connection UK) for example. Either that or his anus is the diameter of an orange... Could be handy for smuggling drugs.
Hahaha lmao this thread.. On the other hand when I tightin my FW adjuster it brings the TOB closer to the the pressure plate.. But my release point is very close to the floor... Hmmmm
2001 GT - True Blue
Old 10-05-2013, 08:15 PM   #23
New clutch by chance? You should have very little, if any air gap between the tob and pp.
Old 10-05-2013, 08:27 PM   #24
slow281
sixpac's Avatar
Region: Nebraska
Clutch is brand new.. Right now there is like <1/8 inch of gap.. But any less and it squeaks..
2001 GT - True Blue
Old 10-05-2013, 08:28 PM   #25
Should never squeak.. did you use a Ford tob? What brand clutch if not
Old 10-05-2013, 08:42 PM   #26
slow281
sixpac's Avatar
Region: Nebraska
LUK ford clutch and ford racing TOB
2001 GT - True Blue
Old 10-05-2013, 08:52 PM   #27
I'm surprised your TOB squeaks. Did you tighten the PP bolts enough?
Old 10-05-2013, 10:16 PM   #28
slow281
sixpac's Avatar
Region: Nebraska
Shop did it very reputable.. But it's just ware the TOB glazes the pp
2001 GT - True Blue
Old 10-06-2013, 05:06 AM   #29
Is the cable tight or is there a little play at the top of the pedal
Old 10-06-2013, 08:29 AM   #30
slow281
sixpac's Avatar
Region: Nebraska
Play
2001 GT - True Blue
Old 10-06-2013, 09:49 AM   #31
9tee7pony's Avatar
When you say "play" is that where the clutch feels floppy at the top. I just had my clutch replaced as well and it has this, it is maybe half an inch of floppy.
9tee7pony is offline   Reply With Quote
Old 10-06-2013, 03:58 PM   #32
slow281
sixpac's Avatar
Region: Nebraska
Yeah it's the distance between your cable has to pull before contact with the PP
2001 GT - True Blue
Old 10-06-2013, 09:47 PM   #33
This^^
Reason I ask is if the pressure plate bolts aren't tight enough, it's fingers dont extend enough and the cable requires extreme over-adjustment to disengage the clutch at all. Obviously disengagement occurs RIGHT off the floor when this happens, so I wanted that ruled out.. going forward, I'm not so sure about the low pedal right now.
Old 10-06-2013, 09:50 PM   #34
slow281
sixpac's Avatar
Region: Nebraska
This^^ Reason I ask is if the pressure plate bolts aren't tight enough, it's fingers dont extend enough and the cable requires extreme over-adjustment to disengage the clutch at all. Obviously disengagement occurs RIGHT off the floor when this happens, so I wanted that ruled out.. going forward, I'm not so sure about the low pedal right now.
No my play is before the TOB even touches the fingers
2001 GT - True Blue
Old 10-06-2013, 10:00 PM   #35
Typically how it's supposed to be. I wouldn't think there's any issue there. Just strange that it engages close to the floor. That's atypical for a new cable clutch.
06:41 AM
