Installing aftermarket head unit help - Mustang Evolution
Old 10-05-2013, 05:11 PM   #1
Kbasham5's Avatar
Just purchased a Pioneer FH-X700BT stereo for my 2001 Mustang Gt with the Mach 460 system. What else do I need to get to get it working properly? Thanks in advance for the help.
Kbasham5 is offline   Reply With Quote
Old 10-05-2013, 05:11 PM   #2
wire harness to connect to your stock one and to your pioneer one
Mustangman705 is offline   Reply With Quote
Old 10-05-2013, 05:29 PM   #3
Kbasham5's Avatar
Where can I get a wire harness?
Old 10-05-2013, 05:46 PM   #4
walmart
Old 10-05-2013, 05:52 PM   #5
looks like this ... E2 Car Stereo Wiring Connector for 1994 and up Ford Vehicles | Canadian Tire just cut the green and white connectors off, tape up those wires... then wire your new pioneer wire harness, wire to wire on this one... then clip it into the wire harness inside your dash, and the black one u put the silver square plug inside ur dash into it... hope that makes sence
Old 10-05-2013, 06:34 PM   #6
Kbasham5's Avatar
I think I understand. Lol
Old 10-05-2013, 07:40 PM   #7
Kbasham5's Avatar
Will the amps and everything work when using that harness?
Old 10-05-2013, 10:59 PM   #8
yup, that's the only harness that will work btw ... im pretty sure that square metal one is for the amps
Old 10-05-2013, 11:02 PM   #9
Old 10-06-2013, 08:49 AM   #10
Xtrosity's Avatar
The RCAs will give a signal to the woofers and you head unit powers the highs. What I did with mine was set a high pass on the highs and set the woofers to sub. I have an appradio 3 though, but most of pioneers head units it's allow you to do this. This was the best sound I could get out of the stock mach 460. Best bet is to replace everything when you have the time and money. The only problem I'm having is finding a good set of 5x7/6x8 components for the front. All I ever come up with is kicker... Best of luck to your install. Like someone said earlier make sure to wire the remotes together to turn the woofer amps on or else you won't have any bass.
Xtrosity is offline   Reply With Quote
Old 10-06-2013, 09:11 AM   #11
Kbasham5's Avatar
Ok. You just completely lost me. I'm not very knowledgable when it comes to stereos.
Old 10-06-2013, 09:15 AM   #12
just do what I said man and you will have your stereo working great.. its pretty straight forward once you get the wire harness... I included a pic of inside the dash to show you what plugs you need... ignore the rest
Old 10-06-2013, 10:09 AM   #13
Xtrosity's Avatar
Once you get the harness, you will see what we mean. Almost all aftermarket radios use the same color pattern, so you just connect all the wires from the stereo to the harness and plug the harness into the stock connectors show in the pic. The high pass and sub settings are for after you have it all Plugged in and working. They are located in the settings of the radio. The working harness will have 2 blacks (ground) and 2 green (remote) wires. Connect the two blacks together and the two greens together and use that for your ground and remote wire off of the radios wires. Once you actually look at it, it will all make sense.
---------- Post added at 08:09 AM ---------- Previous post was at 08:04 AM ----------
You will also need a dash kit to install the stereo as well.
Old 05-14-2014, 10:16 PM   #14
UNDERWORLD778's Avatar
What about the Orange cable used for the radio signal
Sent from my SGH-T599N using Mustang Evolution mobile app
UNDERWORLD778 is offline   Reply With Quote
Old 05-15-2014, 08:23 AM   #15
The antenna will plug into its own separate port. God damn I hate the Mach system in these cars to the point that I prefer the non Mach460/1000 equipped ones. Single amp to bypass and no crazy *** wiring to deal with when gutting the Mach system and installing something that actually sounds good.
Old 05-15-2014, 11:58 AM   #16
Grimace96's Avatar
Go to Crutchfield.com and talk to someone. Tell them you know you need a bypass for the Mach system and they'll know which one you need for your car. If you don't get a bypass then aftermarket stereos won't play through the amplifier.
Grimace96 is offline   Reply With Quote
Old 05-15-2014, 01:58 PM   #17
I did a Pioneer X4500BT unit in my Mach 460, the wiring wasn't too hard. Just had to follow the instructions.
10:42 AM
