What Parts Am I missing - Mustang Evolution
Old 10-07-2013, 03:41 AM   #1
what parts am I missing and what should I not buy
planning to build this car from the ground up and would like to replace everything with quality parts that are going to be able to handle hp and torque in the future...
I plan to buy Alloy USA 8.8 Axles - 31 Spline 5 Lug
Eibach Sport-System-Plus
Steeda Bumpsteer Kit
Steeda X2 Ball Joint Kit
Steeda Rear Shock Tower Brace
Ford Racing Aluminum Driveshaft - 31 Spline
Steeda Finned Differential Cover
Ford Racing 4.10 Gears and Install Kit
Ford Racing Traction - LOK Limited Slip Differential w/ Carbon Discs - 31 Spline
Performance Automatic Street/Strip Valve Body
Power Stop Brake Rotor & Pad Kit - Front & Rear
I can buy all that for 3000 ... I want a solid platform before I do any engine work. what else would you buy... pretty sure that almost everything replaced... anything you would buy differently or anything you would include in that list please let me know
Mustangman705 is offline   Reply With Quote
Old 10-07-2013, 04:05 AM   #2
Slow4V's Avatar
Originally Posted by Mustangman705 View Post
what parts am I missing and what should I not buy planning to build this car from the ground up and would like to replace everything with quality parts that are going to be able to handle hp and torque in the future... I plan to buy Alloy USA 8.8 Axles - 31 Spline 5 Lug Eibach Sport-System-Plus Steeda Bumpsteer Kit Steeda X2 Ball Joint Kit Steeda Rear Shock Tower Brace Ford Racing Aluminum Driveshaft - 31 Spline Steeda Finned Differential Cover Ford Racing 4.10 Gears and Install Kit Ford Racing Traction - LOK Limited Slip Differential w/ Carbon Discs - 31 Spline Performance Automatic Street/Strip Valve Body Power Stop Brake Rotor & Pad Kit - Front & Rear I can buy all that for 3000 ... I want a solid platform before I do any engine work. what else would you buy... pretty sure that almost everything replaced... anything you would buy differently or anything you would include in that list please let me know
Tubular k member
Tubular a arms
Coil over kit
Better brake lines
New motor mounts
New trans mount
Front sway bar and rear sway bar
Lower rear control arms
Lower upper control arms
Full length weld on Subframe connectors
Better radiator / thermostat
Oil cooler kit
Old 10-07-2013, 04:27 AM   #3
Originally Posted by Slow4V View Post
Tubular k member
Tubular a arms
Coil over kit
Better brake lines
New motor mounts
New trans mount
Oil cooler kit
the eibach kit comes with
Front Struts
Rear Shocks
Sportline Lowering Springs - Progressive rate
35mm Tubular Front Sway Bar with bushings
25mm Solid Rear Sway Bar with bushings
I have maximum motorsports lower control arms
so after that I guess your saying..
tubular a arms
and sub frame connectors
the other parts you mentioned would be better to buy when I start the engine build rite... what do you think
Old 10-07-2013, 04:40 AM   #4
Slow4V's Avatar
the eibach kit comes with Front Struts Rear Shocks Sportline Lowering Springs - Progressive rate 35mm Tubular Front Sway Bar with bushings 25mm Solid Rear Sway Bar with bushings I have maximum motorsports lower control arms so after that I guess your saying.. tubular a arms and sub frame connectors the other parts you mentioned would be better to buy when I start the engine build rite... what do you think
No kmember ?
So do you actually have the money?
A lot of people just ask a lot but never actually buy anything lol
Old 10-07-2013, 06:47 AM   #5
02GTvert's Avatar
Do a kmember kit with no spring perches..and coil over...**** eibach.
02GTvert is offline   Reply With Quote
Old 10-07-2013, 09:56 AM   #6
No kmember ?
haha yah I had 12k to spend on a car when I bought this one for 4k... spent some money on the car normal maintenance and smoked headlights grill delete, mach 1 chin, tune up oil changes stuff like that but still have enough to get this build started and don't want to miss anything or have to go back and replace anything because I cheeped out...
---------- Post added at 08:53 AM ---------- Previous post was at 08:50 AM ----------
haha is there a kit you recommend.. could you shoot me a link where I can purchase it
---------- Post added at 08:56 AM ---------- Previous post was at 08:53 AM ----------
I added QA1 Pro-Comp A-Arms
QA1 Pro-Comp A-Arms
Russell Stainless Steel Braided Brake Line Kit - Front & Rear
Old 10-07-2013, 09:58 AM   #7
Venomouz831's Avatar
What's you're goals for the car
)02 Gt, Founder of WE2G
Old 10-07-2013, 10:58 AM   #8
to build it into a quality reliable sports muscle car
a reliable daily driver that goes to the track couple times a month and can easily run with the majority of built cars I will encounter
.. would like to build a solid foundation before doing any engine bay work... future potential mod will most likely be forged internals and a blower or turbo .. but since I have the extra money I saved on buying a car I would like to replace almost every part that would make for a quality performance upgrade.
---------- Post added at 09:58 AM ---------- Previous post was at 09:55 AM ----------
other then whats listed above and rims and tires anything else you can think of that iam missing or should do differently... of course I will have an exhaust as well
09:30 AM
