Cai problem? - Mustang Evolution
Old 10-09-2013, 03:07 PM   #1
Kuhn77's Avatar
Cai problem?
Ok not sure what's going on...my 02 GT has a weird noise coming from the area of the cold air intake. It does it mostly when it's idling and when you rev the engine it tends to stop after a second. If it stays at idle while making the noise after about 10 seconds the engine will almost always die. I took the while thing apart, replaced the air filter and nothing has helped. Not sure what to do next. Anybody have any thoughts?
Kuhn77 is offline   Reply With Quote
Old 10-09-2013, 03:08 PM   #2
Kuhn77's Avatar
I made a video of the noise but not sure how to post it
Old 10-09-2013, 03:24 PM   #3
clean your maf
Mustangman705 is offline   Reply With Quote
Old 10-09-2013, 03:27 PM   #4
Kuhn77's Avatar
Originally Posted by Mustangman705 View Post
clean your maf
The sensor?
Old 10-09-2013, 03:40 PM   #5
Rm360's Avatar
The sensor?
Yes you can try cleaning the sensor and the inside of the housing , also check the screen inside to make sure there is no blockage, be sure to go to the auto parts store and get a can of MAF cleaner
Old 10-09-2013, 03:44 PM   #6
yah take it off. you will need to get a special screwdriver bit tho... its a torqs or whatever with a hole in the middle.. auto parts store sells them.. take it off spray it really good with maf cleaner and do not touch the wires .. let it dry completely... and even if its not the issue its good to clean it anyways
Old 10-09-2013, 03:54 PM   #7
Kuhn77's Avatar
I'll give it a shot...thanks a lot for the help guys.
Old 10-09-2013, 04:08 PM   #8
v8pony's Avatar
Is it like a weird bloooop bloooop type of noise? If so I had the same problem, could not for the life of me figure it out...noise stopped when I went AM cai lol, sucks cuz our stocker does a pretty damn good job so I essentially spent 100$ for the noise to go away lol
2002 5spd GT
Feb 2013 Mustang of the Month
Old 10-09-2013, 05:04 PM   #9
Mfore33's Avatar
That bloop bloop could be a backfire thru the intake. Mine would do that sometimes. I thought I had. Timing issue but a friend told me to check my exhaust for leaks. Turns out I had a few holds in the pipe. This lets air in and it would sometimes ignite the unburnt fuel causing the sound to travel and I could hear it at the intake.
Old 10-09-2013, 05:14 PM   #10
Is this noise sort of a (I'll use Cliffyk's description) French horn sound? Or a very deep hum?
If so it could be the Idle air control valve is worn out and vibrating.
Old 10-09-2013, 05:20 PM   #11
Kuhn77's Avatar
It's a deeper sound...Kind of like a deep rumble. Would any if these cause it to idle down and the car die after a few seconds. It doesn't always die..sometimes the idle will get super low like it's about to die and then the noise stops and the idle goes back to normal.
Old 10-09-2013, 05:24 PM   #12
Mfore33's Avatar
Well with that information I would suspect the aic to be faulty. The faulty aic will not keep the engine running at idle. When mine went out I would need to apply brakes and a little gas to keep running at stop lights. If you have a buddy with a mustang ask to swap the aic from his and see if the problem goes away.
Old 10-09-2013, 05:40 PM   #13
My car was making a French horn sound. It would go away after revving the engine a bit. It was very intermittent. And the engine never died. I was never able to see, or hear where the noise was coming from. I couldn't get out and get the hood opened before it would stop.
Another person had the same issue in a recent thread and one of the forum members linked a write up about the IAC being a probable cause.
I changed my IAC about a week ago and I haven't heard the noise since.
The idle is also much better now. It holds RPMs better when letting out the clutch from a stop and the RPMs don't "hang" like they used to.
Old 10-09-2013, 08:20 PM   #14
cliffyk's Avatar
It is the IAC, here is why...
Old 10-09-2013, 08:44 PM   #15
Kuhn77's Avatar
How hard is the IAC to replace? I'm far from a master mechanic but can turn a wrench. Something I can do at home?
Old 10-09-2013, 08:50 PM   #16
Mfore33's Avatar
Easy. Just 2 bolts and a connector
Old 10-09-2013, 08:54 PM   #17
Kuhn77's Avatar
Oh not bad at all...I appreciate everyone's help. Gonna work on it tomorrow. Thanks again.
Old 10-18-2013, 03:54 PM   #18
Kuhn77's Avatar
Well I went down and bought a new IAC for 76 bucks and put it on in about 10 mins....problem solved. The noise is gone, idles steady, and runs perfect. Thanks for help.
11:20 AM
