03 mach 1 super charger - Mustang Evolution
Old 10-09-2013, 04:01 PM   #1
03Graymach's Avatar
Was wonder what all I need to get to put the stock supercharger off an 03 cobra on to my mach
03Graymach is offline   Reply With Quote
Old 10-09-2013, 04:48 PM   #2
Lower intake, cobra alt and mount. You'll probably have to ditch the shaker as well.
Old 10-09-2013, 04:50 PM   #3
I've seen guys with Twin Screw SC's before running the shaker.
Old 10-09-2013, 05:08 PM   #4
03Graymach's Avatar
Yeah I have seen people run the cobra super charger with the shaker it just sticks up more and I'm guessing still a inter cooler
Old 10-09-2013, 05:18 PM   #5
Slow4V's Avatar
A lot and a lot and a lot of parts
More than what these guys think
Old 10-09-2013, 05:23 PM   #6
03Graymach's Avatar
Originally Posted by Slow4V View Post
A lot and a lot and a lot of parts More than what these guys think
So it would just be best to order a pro charger kit from am
Old 10-09-2013, 05:28 PM   #7
Slow4V's Avatar
Eaton swap usually goes for like 4,000
You can get a Vortech kit brand new for like 3300-3600
Old 10-09-2013, 05:44 PM   #8
03Graymach's Avatar
Eaton swap usually goes for like 4,000 You can get a Vortech kit brand new for like 3300-3600
I was looking that the vortech kit on am but was wondering what was needed for the stock 03 cobra since I'm running the stock bottom end and only going to run 8 to 10psi
Old 10-09-2013, 05:58 PM   #9
Slow4V's Avatar
Parts list for cobra swap
Old 10-09-2013, 05:59 PM   #10
Slow4V's Avatar
Mach 1st safely can only push around 5psi
Winter maybe 7-8 TOPS
Old 10-09-2013, 06:41 PM   #11
03Graymach's Avatar
Mach 1st safely can only push around 5psi Winter maybe 7-8 TOPS
I'm from texas we don't have winters really but thanks for the heads up I have my motor out not will look into the parts of the bottom end
Old 10-09-2013, 10:08 PM   #12
Just get a S trim, intercool it and have your tuner dial you in to around 400rwhp and go have some fun with it.
Just make sure you have all your "bolt ons" done, the fuel system to support it and the suspension/driveline to support it too. Putting the supercharger on a stock car will get you good dyno numbers but **** 1/4 mile times.
02:37 PM
