3v in sn95? - Mustang Evolution
Old 10-09-2013, 09:28 PM   #1
godsdisciple85's Avatar
3v in sn95?
anybody done it? any major problems? I can get a cheap 3v with under 50k miles with an ecu...it will go into a 98 gt with a 4r70
godsdisciple85 is offline   Reply With Quote
Old 10-09-2013, 09:52 PM   #2
You'll have to re-wire the entire car plus there will be other stuff. You'll spend WAY more money getting it in and running than you will just finding a good 2V or even a good 4V.
Old 10-09-2013, 10:35 PM   #3
Mfore33's Avatar
Unless you can get engine wireing harness and other misc parts from a donor car
Old 10-09-2013, 10:49 PM   #4
Slow4V's Avatar
3V are junk IMO
Old 10-10-2013, 08:34 AM   #5
Originally Posted by Slow4V View Post
3V are junk IMO
Not at all just different. VVT is a really nice feature, the heads flow great, plenty of options in the aftermarket. If I had an 05-09 I would not think twice about building it up with some ported heads, a good tune, cams etc...
With that said if you have a SN95 I have no clue in hell why you would want to put a 3V in. You can do a nice stock 2V with cams and make more power than a stock 3V and blowers are cheaper too AND the aftermarket is bigger. Also why not just swap in a 4V vs a 3V if you have a SN95? Its a 90% drop in.
Old 10-10-2013, 09:11 AM   #6
1lowGT's Avatar
Yeah I would go with the 4v
Old 04-07-2014, 02:11 PM   #7
D3vst8r96gt's Avatar
So much bad info in this thread.
I know its old but I came across it while googling other swaps.
3v can drop in pretty easy, logan motorsports makes a kit, its been out for awhile. It not a common swap its not even a hard swap infact if you can swap a head on a 2v you can swap a 3v motor in. No need to rewire
Why? 3v mustangs had aluminum blocks, heads flow way better, power band is different, WAY cheaper then a 4v swap.
D3vst8r96gt is offline   Reply With Quote
Old 04-07-2014, 05:02 PM   #8
You can swap a 4V for less than the cost of the Logan kit itself if you get one out of a Mark VIII. Not to mention the Teksid block in the Mark is a better block than the WAP/WAP variants. Flow numbers for the 3V are good but 4V is better and will stay better with any porting/work. And then you have the TFS heads for the 2V. I am not bashing the 3V but its not even close to cost effective to go 3V vs 4V or even building the 2V already in the car. But the 3V IS a great motor for the 05-10 that doesn't get enough credit and if you haven't heard a hot cammed 3V you need to.
Old 04-07-2014, 05:43 PM   #9
Finding a good 4v for the price of the Logan kit would be a feat. Putting one together would be fun too... I got lucky on mine c heads and a teksid for 150 (block needed work).... its possible but there are way more 3v motors vs c headed motors....
As for block strength ...both are strong enough to withstand a lot. Haven't seen a WAP failure
The D3V
Old 04-07-2014, 06:50 PM   #10
Haven't heard of a WAP failure either but the Teksid is a better block. And agreed on the dearth of good 4v cores out there which is why I mentioned the TFS heads. Although the PI heads ported will put out over 700whp with a good power adder setup, the TFS are good for 900+. I always tell ppl to just go with what came in the car and if you want NA power you get a Fox or 94/95 with a 408 or a Coyote.
Like I said 2V should just build the 2V, 4V should build 4V and 3V should build 3V. Or... for the cost of building any of the above one can do the Coyote and be set. Which is one reason I have not built my Teksid in the garage yet. I keep pricing a built power adder 2V vs the Coyote and not sure its a good idea with more and more Coyote motors becoming available as ppl wreck them/part them out.
Old 04-07-2014, 06:55 PM   #11
Come to the 3v world..... everyone wants a coyote now..... together we can rule the galaxy!!!
The D3V
Old 04-07-2014, 07:03 PM   #12
edited after actually thinking about what I'm saying lol: I've given a good hard look at the 05-09 cars but ppl still want too damn much for nice ones. With the Coyotes being more affordable now ppl need to realize their 3Vs are not really worth that much just like Mach owners find out when they go to sell.
Old 04-07-2014, 07:04 PM   #13
Rapinator126's Avatar
I wouldn't waste your time with a 3v. I was not impressed with my blown 3v when I had it. Back when I had my 2v I preferred it over my 3v. Out of all my mustangs up to my coyote, nothing irritated me more than the 3v.
Old 04-07-2014, 07:19 PM   #14
We just talked about this the other day on the snive forums... .termi vs coyote thread.
Termi 20k and going up
Coyotes coming down found a decked out 13 for 25k under 50k miles and a brembo pack
S197s over priced! Lol people asking over 15k for a normal gt are dumb
The D3V
Old 04-07-2014, 07:25 PM   #15
Ppl want KBB for their lower mile 08-09 and I saw someone wanting $20k for a 2010 recently lol. I don't care what KBB or whatever website you go to tells you your car is worth, your nice 3V is worth $15k max like you said and that's an 09 or 10 with low miles. A 2007 with like 80k on it is $10-$12k max.
03/04 Mach owners find the same thing out when they go to sell theirs for $18k or whatever. $18k and I'll put the extra $2-$3k for a Termi. A real nice Mach is a $14-$16k car MAYBE and that's only because its a numbered car and also that's to the right buyer. If I was looking at a Mach it would be because I wanted a 4V automatic that didn't cost $20k and also came in competition orange.
Old 04-07-2014, 07:27 PM   #16
Don't come to California then, all prices over here are inflated.
Old 04-07-2014, 07:32 PM   #17
That's what automobile shipping companies are for. Or a plane ticket out and gas/hotels back. I see what cars go for in Cali and I laugh.
Old 04-07-2014, 10:06 PM   #18
California cars are, largely, rust free... That's why they demand a higher price in the used automobile market.
straybullitt is online now   Reply With Quote
Old 04-08-2014, 06:31 AM   #19
So are Florida cars and some cars in other southern states which are all a day or two drive away. Or like I said just ship.
Old 04-08-2014, 07:20 AM   #20
Popular misconception that every state except California will provide rusty vehicles.....
Its just typical California inflated market prices.
The D3V
Old 04-08-2014, 10:58 AM   #21
I guy I worked with picked up an 03 CO Termi in San Diego with about 60k on the clock from a private seller. He "said" he paid $18k for it, I've never had a reason to question his integrity but take it for what is worth.
Old 04-08-2014, 11:00 AM   #22
There are good deals out there. I don't doubt that he got it for that price.
Old 04-08-2014, 11:01 AM   #23
The D3V
Yea but the weather of California and a few other states do give it a far less chance of having rust.
Old 04-08-2014, 11:03 AM   #24
Yeah, that's why I say take it for what it's worth. People always under cut what they actually paid.
Old 04-08-2014, 12:43 PM   #25
V6 stang's Avatar
V8 mustangs just seem to be overinflated at the moment.
I was looking in the winter at all ranges.. It was pretty dumb what they wanted. The general ranges are for a 05-09 GT with under 80k they wanted 13-16k... 15k or a Mach with under 100k... 8-10k for a 99-04 GT with under 100k.. 17-20k for 2010 GT an I never searched for coyotes. About 16-20k for the 11-12 v6's BASE though.
2012 Mustang GT Convertible
Roush Exhaust
2003 Mustang GT (Sold)
12:25 PM
