98 motor/trans mount - Mustang Evolution
Old 10-10-2013, 10:08 AM   #1
XSlashDashX's Avatar
Is it easy to replace yourself or no? Which brand should I go with?
Old 10-10-2013, 10:52 AM   #2
They're pretty easy. For the motor you remove the big nuts (lol) holding the mounts to the k member and then jack the engine up a little with a block of wood on the oil pan. Then you just unbolt the old motor mounts, install new ones, drop it back down and torque the nuts.
For the trans mount you just unbolt it from the crossmember, jack the trans up enough to get it out and swap it with the new one.
Old 10-10-2013, 01:36 PM   #3
Any brand I should go with?
Old 10-10-2013, 06:46 PM   #4
Energy suspension is a good one.
Old 10-11-2013, 05:33 AM   #5
Slow4V's Avatar
Trans is easy
Motor mounts are pretty easy , well for me
I go with OEM ford ..
Old 10-11-2013, 06:48 AM   #6
I like the poly ones myself or even solid metal ones but if you do go with rubber ones then ONLY go with OEM Ford as Slow4V suggested. Just FYI the Prothane ones raise your motor up more than stock which can throw off your ds alignment which=stay away.
Old 10-11-2013, 07:04 AM   #7
Slow4V's Avatar
Idk I get discounts from ford so I get them employees cost that's why I go ford and it's actually cheap
10:34 AM
