MGW that great ? - Mustang Evolution
Old 10-10-2013, 02:38 PM   #1
Slow4V's Avatar
MGW that great ?
I have the Tri-AX .. It's loud and sometimes I miss a gear because it's hard to slam gears sometimes. I found a MGW for 125.00 with the race handle never installed. Is really upgrading worth it? and I mean this one is pretty cheap compared to 190.00
Should I make the jump and upgrade? And maybe sell mine for like 75.00?
Thanks
Old 10-10-2013, 02:44 PM   #2
Mile high JDF's Avatar
I have the Tri-Ax in mine and got the opportunity to drive BlackedoutBKR's GT with the MGW. There wash noticeable difference in the distance between throws and how well the shifter centered itself. I found myself double checking to make sure I was in first and not third when taking off. I would go ahead and pick it up, especially since you can recoup that money after you sell yours.
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 10-10-2013, 03:08 PM   #3
Slow4V's Avatar
Yeah.. It's just my Steeda triax is sooooo annoying loud , I can barely talk when I'm rolling in neutral , it makes a lot of noise , and sometimes I miss 3rd, supposely with the MGW you'll never miss 3rd again.
Old 10-10-2013, 03:52 PM   #4
Unfortunately I didn't try banging gears in his car and I didn't get enough seat time to verify if it's quieter or not. However I do know they supply a piece of foam or something like that to help with the noise.
Old 10-10-2013, 03:57 PM   #5
Slow4V's Avatar
Man idk I can't make my mind up
Idk I finally mastered the Steeda were I nail every gear
Think MGW is that much better ?
Old 10-10-2013, 04:04 PM   #6
You said it there... You miss gears sometimes. Get the MGW and that will be a thing in the past. I miss 3rd sometimes but i think its my transmission because it feels like there is a wall there sometimes under heavy acceleration.
Old 10-10-2013, 04:18 PM   #7
DutchManDann's Avatar
One of my buddies drives a Mach 1 with a tri-ax and he is upgrading to an MGW after trying my car.
Another one drives a 99 GT and he switched from a Hurst to an MGW after trying mine.
It's definitely worth it in my opinion
Roxanne- 1998 Mustang GT Convertible: 5-Speed, 2001 PI 2V swap, o/r h-pipe, Magnaflow catback, MGW shifter,
3.73 gears, Auburn LSD, TA diff cover, MM FLSFCs, Ford Strut Tower Brace, J&M SS Brake Lines, and a lot of visual/restoration work.
DutchManDann is offline   Reply With Quote
Old 10-10-2013, 04:25 PM   #8
Slow4V's Avatar
This is the shifter , it's the 1st gen .. Is it still good ? For 120.00 and a shift knob
Old 10-10-2013, 04:31 PM   #9
2002VertGT's Avatar
it's the same one I got, you won't regret it
4.10 Gear/RPM thread
Old 10-10-2013, 04:53 PM   #10
Looks like the same one i have. I got mine new for $190 so thats a good deal.
Old 10-10-2013, 06:12 PM   #11
Slow4V's Avatar
Any pics ?
Old 10-10-2013, 06:22 PM   #12
slow281
sixpac's Avatar
Region: Nebraska
[QUOTE="Slow4V;1822602"]This is the shifter , it's the 1st gen .. Is it still good ? For 120.00 and a shift knob [/QUOTE
Get it.. The 1st gen looks better anyway
Need more Horsepower? Add a sticker. Contact me for vinyl stickers pre-made and custom!
Stick on Horsepower <- Click Here and like my Page!
2001 GT - True Blue
2003 V6 - Zinc Yellow
1990 LX 2.3 - project
sixpac is offline   Reply With Quote
Old 10-10-2013, 06:40 PM   #13
Any pics ?
I'll one up that.
Old 10-10-2013, 06:54 PM   #14
I'm in the minority, I like the Tri-Ax. You can buy $16 gaskets on any of the big sites that quiet it down a little and cut yourself a piece of dynamat just like the one they supply with the new MGW shifters. I never, NEVER miss 3rd which is why I will always stick with them. If you miss 3rd with a Tri-Ax you need to learn how to shift or you have worn out centering springs in yours. I also prefer the notchy feeling of the Tri-Ax, lets me know where I'm at with no guessing.
Another thing I worry about and its probably unfounded is that with the MGW you don't actually have anything bolted together. Its all clamping force. I've heard horror stories from a few ppl of the bolts backing out and the handle twisting. My Rock Crusher/Roush handle is bolted with grade 8 bolts directly to the shifter and isn't going anywhere.
In the end if you aren't sure then you can always pick it up, install it and see how you like it. It isn't like you can't change back to your Tri-Ax in 5 minutes and recoup your money by selling the MGW if you don't like it.
Old 10-10-2013, 09:40 PM   #15
2002VertGT's Avatar
I'm in the minority, I like the Tri-Ax. You can buy $16 gaskets on any of the big sites that quiet it down a little and cut yourself a piece of dynamat just like the one they supply with the new MGW shifters. I never, NEVER miss 3rd which is why I will always stick with them. If you miss 3rd with a Tri-Ax you need to learn how to shift or you have worn out centering springs in yours. I also prefer the notchy feeling of the Tri-Ax, lets me know where I'm at with no guessing. Another thing I worry about and its probably unfounded is that with the MGW you don't actually have anything bolted together. Its all clamping force. I've heard horror stories from a few ppl of the bolts backing out and the handle twisting. My Rock Crusher/Roush handle is bolted with grade 8 bolts directly to the shifter and isn't going anywhere. In the end if you aren't sure then you can always pick it up, install it and see how you like it. It isn't like you can't change back to your Tri-Ax in 5 minutes and recoup your money by selling the MGW if you don't like it.
x1000000 that's a easy sell....mgw for 125...all day. Here are some pics of mine in 1st and then rev I turned my handle towards the driver seat cause I'm only 5'10 and my arms are not that long lol...but I love it
ID:	132124   Click image for larger version
Old 10-10-2013, 09:50 PM   #16
TXstang125's Avatar
I went from a steeda tri ax to a MGW and I like the MGW cause it's firm , short and you can fully adjust where the handle is to your liking it's quiet too. I do miss 3rd sometimes but like soccer said I'm thinking it's my tranny cause the steeda did the same thing but anyway yeah MGW ftw !! Haha
TXstang125 is offline   Reply With Quote
Old 10-10-2013, 10:04 PM   #17
MidnightBlueGT's Avatar
Thats neutral for me. Love it
ID:	132130   Click image for larger version
Old 10-11-2013, 06:40 AM   #18
Neutral with my Tri-Ax
Pic of where my hand is with my elbow resting all the way on the console and my seat leaned back "gangsta" style.
Have a Hurst T-Handle showing up Tuesday to replace the Cobra knob so I can actually grab and slam this mother into gear vs having my hand slip off AGAIN.
Oh, Midnight, I had one of those knobs in this car as well, the leather will start to delaminate from the metal after awhile.
Old 10-11-2013, 07:03 AM   #19
Slow4V's Avatar
B
Old 02-13-2014, 09:13 AM   #20
Switching to a 3650 as soon as it comes in and I get my intake coolant leak fixed/intake replaced. And I picked up a used Tri-Ax for $100 shipped with an OEM Mach knob. I was kicking around getting a MGW but I just have had such good luck with the Tri-Ax I'm sticking with it.
And for people who keep touting adjustability, there are products out there that can get your stock tri-ax handle in all different locations.
If I want it closer to me I'll move it over to the other side of the shifter. Tri-Ax handle is already tilted towards the driver.
This is 3rd gear lol
When the 3650 comes in I my put the Roush shifter handle I have back on with this plate and get some hyper long reach.
Old 02-15-2014, 01:20 AM   #21
Speed_Mister's Avatar
Region: Arkansas
Don't think just buy it you won't regret it at all! Oh! Then just sell you steeda shifter on eBay for over prices or something. It's a win win.
2004 Mustang GT 5 Speed
Full Bolt Ons
370rwhp 470rwtq
12.1 @ 117.9 (1.7) in 1/4th
7.6 @ 92.1 (1.6) in 1/8th
Old 02-15-2014, 02:41 AM   #22
DaBluedude's Avatar
I have the tri ax in my Mach and I've driven the mgw back to back with mine. The mgw is looser, not As notchy, and not as positive on engagement. It is easier to shift with casually but a lot easier to miss gears with. It also has shorter shifts. Long story short, both are good shifters, but the mgw is more casual and easy shifting, where the tri ax is more notchy and positive on engagement. I prefer the tri-ax.
2003 Mach 1
Old 02-15-2014, 06:56 AM   #23
This is exactly why I stick with the Tri-Ax. I have a penchant for just slamming the living **** out of gears going 1-2 and 2-3 when I don't have a boogered trans like I do now. By the end of the month hopefully the 3650 is in and I'm back to slamming away.
Old 02-18-2014, 10:40 PM   #24
Jrh2592's Avatar
I have the MGW in my 04 GT. Shifts are smoother than you can imagine and the throws are so short and precise that it makes missing a gear nearly impossible. You will not be disappointed with the MGW
Jrh2592 is offline   Reply With Quote
Old 02-19-2014, 06:30 AM   #25
Trust me, the Tri-Ax is just as precise, it all comes down to personal preference between the two honestly. Tri-Ax is noisy and can be notchy. I like the centering springs in the Tri-Ax. I just got my new/used one in the mail yesterday and was pulling on the lever just to make sure the springs felt good and that left spring that centers from 2-3 is STOUT. I will say for those having issues with the Tri-Ax and hitting a gear you either have a messed up trans, need to adjust/replace your clutch cable/quadrant or you're just an idiot.
10:40 AM
