I want to lower my car... Have some questions - Mustang Evolution
Old 10-11-2013, 10:03 AM   #1
Ok, so for the next mod on my 00 GT I want to lower it. I have a few questions though. What all is needed to lower the vehicle? I see on AM they have like springs for $250-300. Would that be all I need or is there other parts required? Also how does the car handle after being lowered?
Thank you for all of the help!
Bill36 is offline   Reply With Quote
Old 10-11-2013, 10:10 AM   #2
If you go lower than 1-1.5 inches it's recommended to get CC plates or bolts for alignment. If you don't go that low then you could go without.... Depending on your miles it might be a smart Idea to get new shocks and struts also.
Old 10-11-2013, 10:11 AM   #3
Rosco's Avatar
That's all you need to lower it, technically. You'll need an alignment afterwards, and if you drill out the rivets and get camber bolts you shouldn't have any issues getting back into spec. I your shocks are blown or a cheaper brand then they will wear out faster and create a harsh ride. If you get x2 ball joints it will "lower" you even more.
1998 Bright Atlantic Cobra - 3:73's, BBK ls, Pro 5.0, 96 Cobra STB, Borla XR-1 Catback, Custom Catch Can, Spec clutch, MM Firewall adj, FRPP wires, RSD, Spoiler delete, 245/275 BF Goodrich g sports on chrome 95 cobra r's
1998 V6 Mustang : SOLD!
Rosco is offline   Reply With Quote
Old 10-11-2013, 10:21 AM   #4
Horseplay's Avatar
all i bought for my gt was lowering springs and it dropped more than 1.5" and i didnt get cc plates or anything. still runs fine. alignment is off a tad but no biggie for me
Low2v
Old 10-11-2013, 10:25 AM   #5
I do not plan on dropping it that far, probably not best 1.5 inches. Any recommendations on good lowering springs?
Old 10-11-2013, 10:34 AM   #6
33wings's Avatar
Can't go wrong with SR performance. Drop is estimated to be 1.5 inches and is a great price
33wings is offline   Reply With Quote
Old 10-11-2013, 10:55 AM   #7
H&R Race springs without isolators... It will give you just about a 1.5" drop and your car will handle so much better.
Old 10-11-2013, 11:17 AM   #8
Thanks for the suggestions. How hard are they to put on? I am not very car savvy. I would assume I would need my mechanic to do it?
Old 10-11-2013, 11:27 AM   #9
mystang50's Avatar
I went with SVE from late model resto,,,cheaper, and I don't have any complaints
Old 10-14-2013, 08:00 AM   #10
ColeJohnson's Avatar
They're very easy to do. I didn't even used a spring compressors.. I just used a breaker bar and leverage and let physics do the rest. My whole spring swap took maybe an hour from putting the jack under to taking it on it's first drive.
But also I had already installed steeda bump steer, MM c/c plates, and steeda x2 balljoints. I didn't replace shocks struts yet to see how it'd do.
My stock shocks bottomed out on every little bump and it was a terrible sound and ride. Switch to Tokico d-spec shocks and struts and it fixed everything. Rides like a champ and very comfortable.
I installed the isolators with the springs so overall my drop was about 1.75 front and a little more in rear. If I skipped the isos then I'd be at or a little more than 2" drop front.
Lowering and changing out those parts has made a world of difference not only aesthetically but performance too.
2016 Comp Orange GT (current)
Old 10-14-2013, 08:18 AM   #11
Iggy's Avatar
You didn't have to have the adjustable pan hard bar ? I here a lot of guys using them
Iggy is offline   Reply With Quote
Old 10-14-2013, 08:20 AM   #12
bullitt1075's Avatar
Send a message via Skype™ to bullitt1075
+1. I run H&R race springs on my Bullitt. They aren't the lowest, but they are a high spring rate which improved my cars handling greatly.
Proud owner of Bullitt #1075
bullitt1075 is offline   Reply With Quote
Old 10-14-2013, 08:45 AM   #13
No. Stock bars do just fine. A bar is a bar.
Old 10-14-2013, 09:50 AM   #14
Mile high JDF's Avatar
99-04 mustangs don't come with a Panhard bar. You shouldn't need one unless your axle is out of alignment.
I'll give a +2 to the H&R race springsk, I loved mine. Or you could just cut the stockers.
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 10-14-2013, 11:08 AM   #15
Iggy's Avatar
Originally Posted by JDF View Post
99-04 mustangs don't come with a Panhard bar. You shouldn't need one unless your axle is out of alignment. I'll give a +2 to the H&R race springsk, I loved mine. Or you could just cut the stockers.
I am looking to lower mine I have the eibach struts and shocks I want a 1.5" drop do I need the camber casters?
Old 10-14-2013, 11:12 AM   #16
Slow4V's Avatar
H&R super sports suppose to be the lowest drop
I just cut my springs lol
But if I get springs I'm getting the H&R SS and Steeda lower ball joints
Old 10-14-2013, 11:39 AM   #17
You can probably get away with camber bolts, that's what Bullitt1075 did on his, or if you wanna do it correctly you can do the plates. I never noticed any unusual wear when I had my Race springs and I didn't have either of those.
Old 10-15-2013, 11:34 AM   #18
04sonicbgt's Avatar
As much as it hurts to have to let someone else do this to my car,(I have always done any bit of work on my cars) she's on the lift finally getting the suspension and some springs done, just couldn't find time to do it myself. Let's hope all goes well
Sonic blue 04 GT~~bolt ons- headers, steeda tri ax, hi tech stage 2 cams coming this winter.
04sonicbgt is offline   Reply With Quote
Old 10-15-2013, 11:35 AM   #19
Venomouz831's Avatar
Ouch you're gonna be out a pretty penny
)02 Gt, Founder of WE2G
Old 10-15-2013, 11:38 AM   #20
04sonicbgt's Avatar
yeah unfortunately:/. It took a lot to finally convince me to just take it in lol
Old 10-15-2013, 11:39 AM   #21
If you have some basic tools and a whole day the you could of gotten it done
Old 10-15-2013, 11:44 AM   #22
04sonicbgt's Avatar
I originally planned today to do it, off work and class got canceled but I woke up and it's like a hurricane outside.... And my garage is currently a storage unit for my sisters belongings lol...
Old 10-15-2013, 11:48 AM   #23
Lol I feel youre pain on the garage thing. I couldn't fit my car on my old house garage. Now I have a 2 car garage and it really helps you out
Old 10-15-2013, 12:16 PM   #24
04sonicbgt's Avatar
Yeah it's unfortunate hah, but I'll have to deal, I'll post up a pic when she's all done!
Old 10-15-2013, 12:39 PM   #25
Skulls98GT's Avatar
I put Eiboch spotline springs on my GT when I had it. Loved them. 1 3/4" drop in the front 1 1/2" in back. I would suggest Caster Camber Plates, it makes alignments go much smoother. Also some people like to leave off the isolators for a bigger drop... My friend did that and now his car squeaks when you hit bigger bumps.
http://www.americanmuscle.com/eibach...-7904gtv6.html
Skulls98GT is offline   Reply With Quote
Old 10-15-2013, 04:04 PM   #26
04sonicbgt's Avatar
Went and picked it up a little bit ago, and im surprised to say in pleased with it!
Old 10-15-2013, 04:25 PM   #27
Looks great! What springs did you go with?
Old 10-15-2013, 04:32 PM   #28
04sonicbgt's Avatar
Thanks! I went with sr, and I'm actually kind of surprised. I was hearing they don't drop that much but it's right where I wanted it!
Old 10-15-2013, 04:49 PM   #29
Nice! Those are supposed to drop 1.5" right?
Old 10-15-2013, 06:04 PM   #30
04sonicbgt's Avatar
yeah!
Old 10-15-2013, 06:38 PM   #31
Don't worry give em a few days to settle
Old 10-15-2013, 07:28 PM   #32
04sonicbgt's Avatar
So I've heard, just a little bit right?
Old 10-15-2013, 07:31 PM   #33
Yea just a few more mm
Old 10-16-2013, 08:04 AM   #34
BBK springs, Tokico Illumina shocks/stuts, Max Motorsports CC plates, Steeda LCAs, stock UCAs. Rides great, just stiffer like any lowered car is going to be. If you are expecting a stock cushy ride you will be disappointed.
Old 10-16-2013, 08:14 AM   #35
mystang50's Avatar
looks sexy
05:53 PM
