Rear alignment? Solid axle - Mustang Evolution
Old 10-11-2013, 12:37 PM   #1
slow281
sixpac's Avatar
Region: Nebraska
Is there something I can do to get it straight.. Is shifted to the right about (passside) a good inch or two
Need more Horsepower? Add a sticker. Contact me for vinyl stickers pre-made and custom!
Stick on Horsepower <- Click Here and like my Page!
2001 GT - True Blue
2003 V6 - Zinc Yellow
1990 LX 2.3 - project
sixpac is offline   Reply With Quote
Old 10-11-2013, 12:41 PM   #2
Venomouz831's Avatar
When I asked about getting a mustang aligned in the rear they said they couldn't because it's sra. But when I said I had a cobra with the irs they were able to straighten it out. So try calling an see what the shops will say
)02 Gt, Founder of WE2G
Old 10-11-2013, 01:16 PM   #3
slow281
sixpac's Avatar
Region: Nebraska
What that's kinda what I thought initially..
2001 GT - True Blue
Old 10-11-2013, 02:07 PM   #4
Mile high JDF's Avatar
I know a panhard bar will straighten that out. I dont' know what else you would need to go with it though
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 10-11-2013, 04:16 PM   #5
Your control arm bushings are worn out.
Old 10-11-2013, 04:19 PM   #6
slow281
sixpac's Avatar
Region: Nebraska
There not tho.. There solid and fine.. Only 80k on her
2001 GT - True Blue
Old 10-11-2013, 04:22 PM   #7
Well something is wrong. Has that car ever been wrecked?
Did this just occur or did you buy it like that?
Old 10-11-2013, 04:25 PM   #8
slow281
sixpac's Avatar
Region: Nebraska
Well something is wrong. Has that car ever been wrecked? Did this just occur or did you buy it like that?
I'd assume I bought it like this.. I just notice because of the wide tires..
2001 GT - True Blue
Old 10-11-2013, 04:29 PM   #9
Hmmm...
Mine is offset to that side but only by about a 1/4 inch.
I still say:
BUSHINGS!!!!!!
Old 10-11-2013, 04:40 PM   #10
slow281
sixpac's Avatar
Region: Nebraska
Hmmm... Mine is offset to that side but only by about a 1/4 inch. I still say: BUSHINGS!!!!!!
How a bad bushing look like?
2001 GT - True Blue
Old 10-11-2013, 04:43 PM   #11
jduckz5.0's Avatar
Check which axles you have...might have the wrong length axle...
jduckz5.0 is offline   Reply With Quote
Old 10-11-2013, 04:48 PM   #12
It's hard to tell if they're bad looking at them when installed on the car, but the rubber deteriorates and gets cracked and deformed.
There was a fairly recent thread where someone had this same problem and the bushings, or a bushing was the culprit.
Unless something is bent, there doesn't seem to be anything else but the bushings that could let it get that far out of alignment.
Old 10-11-2013, 04:53 PM   #13
slow281
sixpac's Avatar
Region: Nebraska
There stock
2001 GT - True Blue
Old 10-11-2013, 04:54 PM   #14
Screaming Mach's Avatar
Had the same problem it was the bushings !!
Screaming Mach is offline   Reply With Quote
Old 10-11-2013, 08:49 PM   #15
slow281
sixpac's Avatar
Region: Nebraska
It's hard to tell if they're bad looking at them when installed on the car, but the rubber deteriorates and gets cracked and deformed. There was a fairly recent thread where someone had this same problem and the bushings, or a bushing was the culprit. Unless something is bent, there doesn't seem to be anything else but the bushings that could let it get that far out of alignment.
Could I just get ne LCA and call it good?
2001 GT - True Blue
Old 10-11-2013, 10:06 PM   #16
Depends on if your uppers are still good, but, yes, I'm betting new control arms would solve your problem.
Or at least get it closer... These ARE production cars.
Old 10-13-2013, 07:33 AM   #17
Slow4V's Avatar
Mine when I replace them
Old 10-13-2013, 10:24 AM   #18
slow281
sixpac's Avatar
Region: Nebraska
See mine look nothing like that pretty solid. Not saying there not bad.. But idk
2001 GT - True Blue
10:26 AM
