Used cams....? - Mustang Evolution
Old 10-11-2013, 07:39 PM   #1
calebnaasko's Avatar
Used cams....?
Could used cams be a good deal? If they were barely used or have low miles in a stang?
Going to be posting a lot of questions soon
calebnaasko is offline   Reply With Quote
Old 10-11-2013, 07:44 PM   #2
Slow4V's Avatar
Originally Posted by calebnaasko View Post
Could used cams be a good deal? If they were barely used or have low miles in a stang? Going to be posting a lot of questions soon
Fine just make sure they aren't messed up
Old 10-11-2013, 07:48 PM   #3
Will I need it dyno tuned? Please give me more info
Old 10-11-2013, 07:55 PM   #4
What more info would you need? You inspect them and make sure the part numbers jive. I've run multiple used cams just fine in cars I've used. Yes you need a dyno tune, I mentioned that in another thread, they generally run $600 for a good custom tune.
Old 10-11-2013, 08:14 PM   #5
Like tuning and what not and what kind of cams will run in my 98 2v. And I absolutely need a dyno tune?
Old 10-11-2013, 09:22 PM   #6
Yes... you absolutely need a dyno tune or it'll run like ***. This is not a cheap hobby. Cams will need to be properly degreed by someone who knows what they are doing, you can't just line up dots (which you should not even do on a pushrod). And then a custom dyno tune or at the very least a mail order tune which will likely not be totally optimal.
Old 10-12-2013, 03:03 AM   #7
Slow4V's Avatar
I know people with cams that just have a SCT tune and they run fine. Although dyno tune should be your main goal in getting a tune.
06:21 PM
