Battery light - Mustang Evolution
Old 10-11-2013, 08:03 PM   #1
JB_MUSTANG_V6's Avatar
Battery light
Okay guys, quick question. When I punch it and rev out to around 5-5500k rpms, the battery light blinks... What could be causing this?
JB_MUSTANG_V6 is offline   Reply With Quote
Old 10-11-2013, 09:33 PM   #2
1996mustang's Avatar
Alternator probably going bad, maybe a bad connection on the terminal.
Old 10-11-2013, 10:04 PM   #3
I got my alternator tested and it's fine. I mean it would have to be a connection problem somewhere I guess.
Old 10-13-2013, 09:35 PM   #4
Grrrr....'s Avatar
I would clean up battery terminals, replace connectors if needed, and make sure the battery tie-down is doing its job. That's weird though.
Grrrr.... is offline   Reply With Quote
Old 10-15-2013, 12:09 AM   #5
have you figured out what it is... I know its already been said but it is your alternator.. the battery light will only come on from your alternator. yeah you may have had it tested but it could just be intermitted ... the brushes are prob starting to wear out...
Mustangman705 is offline   Reply With Quote
Old 10-15-2013, 12:12 AM   #6
Venomouz831's Avatar
Had the same problem on my 2v. Turned out to be a bad connection
)02 Gt, Founder of WE2G
Old 10-15-2013, 12:13 AM   #7
Where u been at mustang man? Lol
KoolPwny is offline   Reply With Quote
Old 10-15-2013, 12:16 AM   #8
hhhaha ok yah could be a bad connection to the alternator... a dead battery wont even give you the battery light, the light is ran threw the alternator so its the only thing that's going to set it off.. maybe make sure the connection is secure but other then...
---------- Post added at 12:16 AM ---------- Previous post was at 12:15 AM ----------
or belt is slipping in witch case its still related to the alternator... check ur belt make sure its not loose or worn
02:21 PM
