Fan not spinning and smoking! - Mustang Evolution
Old 10-16-2013, 01:38 AM   #1
Polar Bear's Avatar
Region: Asia
It sure what to put. Engine starts up but fan isn't spinning and smoke is coming from its center.
Steve
Polar Bear is offline   Reply With Quote
Old 10-16-2013, 05:13 AM   #2
Order a Ford fan. If you HAVE to drive it, unplug it from the center of the fan and stay on the highway so not to overheat. If you have already overheated it, change the oil. Great reason to use synthetic.
You can get one HERE:
Mustangs Unlimited - The Premier Source for Mustang, Shelby and Cougar Parts and Accessories
Old 10-16-2013, 05:36 AM   #3
Polar Bear's Avatar
Region: Asia
Hasn't overheated. Already use Royal Purple. Just started today. Smelled a weird smell. Popped the hood and saw the smoke. Believe it's still the factory fan. Not too many upgrades on this car.
Steve
Old 10-16-2013, 07:02 AM   #4
The smell could have been electrical meaning the fan motor is now shot. When mine went the shroud literally shredded and the blades got sick in the mess and locked it up.
Get a new one, it's a fairly simple install if I remember correctly
Old 10-16-2013, 07:57 AM   #5
Time for a new fan.
Old 10-16-2013, 10:24 PM   #6
Steve96's Avatar
This happened to me, my car had 50k miles, smelled the electrical smoke then temp started to go up. Replaced it with one from my local oreillys was about 80 bucks and a half an hour install.
1996 GT
Old 10-17-2013, 04:35 AM   #7
Yeah, very easy to replace. Pop off the plastic radiator/air cover and fan is attached by a few bolts to radiator. I think i had to remove the battery too. Stick with OEM style.
*Link above takes you to oem fans, FYI
Old 10-17-2013, 05:33 AM   #8
Polar Bear's Avatar
Region: Asia
Thanks everyone. Ordered from the link above based off of the recommendations. I saw one similar on latemodelrestoration.com too but wasn't sure. Now the wait begins. If they ship UPS I won't see it for 30-45 days.
If I unplug the fan is it safe to drive for short distances? The weather here is increasingly cold and I only work a couple of miles from home.
Steve
Old 10-19-2013, 05:46 AM   #9
No, if you happen to run into a traffic jam or accident, sitting idle, your screwed. It'll over heat.
Old 10-19-2013, 12:50 PM   #10
If its cold out and you literally live a few miles away it should be OK. But its still a roll of the dice because you still might have to sit idling.
08:14 PM
