Optima Battery - Mustang Evolution
Old 10-16-2013, 06:35 PM   #1
XSlashDashX's Avatar
Optima Battery
Would the red Optima fit in my 98 GT? Have to get a new battery and motor mounts next week.
Old 10-16-2013, 06:51 PM   #2
You realize there are all different sizes of optimas right?
Old 10-16-2013, 06:54 PM   #3
Didn't know. Ones at oreilly and autozone look the same size.
Old 10-17-2013, 12:54 AM   #4
1996mustang's Avatar
Red34/78 its the one i use in mine. The red75 may work as well but i know i used the one i mentioned
Old 10-17-2013, 09:30 AM   #5
Use a yellow top, why waste your money on a red? Yellows have way more than enough to crank over even a built motor and they are deep cycle too. Let a red discharge a few times and bye bye $250.
Old 10-18-2013, 09:40 PM   #6
I was on Odyssey battery website and the battery they told me to use seem pretty small.
Old 10-18-2013, 09:48 PM   #7
The yellow I had in mine was a 610 I think. Little taller than the stocker but not as wide. I drained that thing down so many times it wasn't even funny because that car sat. Threw it on the charger overnight and fired right up in the morning. Best battery I ever had but not needed on a car that is not going to sit or you can put a tender on. I've got a simple Napa replacement battery in the blue car and it sat for 3 months on a tender last time I deployed. Started right up when I came home.
Old 10-18-2013, 10:16 PM   #8
Thinking just going with a walmart battery, lol. Cheap, 5 year warr, and walmart is everywhere. But you do get what you pay for.
Old 10-18-2013, 10:54 PM   #9
I've got a red top on mine & it's great so far. Atleast it's been great since 2010
Old 10-19-2013, 10:59 AM   #10
Walmart, napa, duralast, advance auto etc... they're all the same battery. You don't need anymore than these for most applications. I needed a yellow top to spin over an almost 11:1 compression brand new engine because with the stock one the high torque starter just went "clunk" against the flywheel. Optima spun that biotch over like a champ and fired right up.
04:10 PM
