trans swap - Mustang Evolution
Old 10-19-2013, 12:03 PM   #1
sam minnick's Avatar
trans swap
What would I need to do to swap my auto out to a 3650 trans
sam minnick is offline   Reply With Quote
Old 10-19-2013, 12:32 PM   #2
MidnightBlueGT's Avatar
Search. A few in depth threads on this. A lot faster than waiting for a proper response.
Old 10-19-2013, 12:59 PM   #3
The Google, she knows much. Id just mod the auto or sell it and buy a stick personally. If you are an 04 especially you should leave it alone. Those transmissions are good for over 700hp in stock form.
Old 10-19-2013, 05:27 PM   #4
1996v6stang's Avatar
Too bad ur in pa cuz id trade you everything straight out of my car haha
1996v6stang is offline   Reply With Quote
Old 10-20-2013, 06:40 AM   #5
I have a 99 and loved the automatic until with 4.10 gears until I supercharged the car I think its too much power for the trans cause its not working near like it did before the charger.. under boost it will not shift into second gear unless I let off the throttle almost completely.. but normal driving it works great
Old 10-20-2013, 04:36 PM   #6
Is the 3650 a good trans
Old 10-20-2013, 05:07 PM   #7
What sort of aftermarket cooler did you put on the trans? Did you do the J-mod or a shift kit? Did you do a full fluid change to include flushing the converter? The automatics in the 99-03 cars can take more power than the motors can. The 04 has what basically amounts to a built trans right from the factory in the 4R75W.
The car in this video is running a totally stock low mileage 3650. Was waiting for the input shaft to blow up and swap to a 26 spline but apparently it never gave up the ghost. You be the judge lol.
[/QUOTE]
Old 10-20-2013, 05:28 PM   #8
This is what Paul tells me
Old 10-20-2013, 05:29 PM   #9
The auto was stock
Old 10-20-2013, 06:55 PM   #10
Your auto died because you put a ton more power through it and didn't do anything to help keep it cool or better lubricated. With a J-mod and a good dual fan B&M cooler that trans would likely still be alive and kicking.
The 3650 is fine. Just because you know someone who had a bad experience doesn't mean they are all garbage.
Also if your goal is to go fast in a straight line, keep it auto and swap in a fresh trans and an aftermarket stall converter. You'll run better 1/4 times with that setup than you will with a stick all other things being equal.
Old 10-20-2013, 07:07 PM   #11
My trans didn't die yet but I'm afraid if I keep running it she will die.. I like going to the track but I enjoy playing with the manual better.. I only been driving the car boosted for almost a week and in normal driving its fine heck even 3/4 throttle it fine but full boost forget it
05:10 PM
