Cylinder 6 miss - Mustang Evolution
Old 10-21-2013, 09:18 AM   #1
Mfore33's Avatar
Cylinder 6 miss
Well my 2000 gt is acting up on me. It started running rough at idle and threw a cylinder 6 misfire. I have swapped the coil and no change. Plugs have 45,000 miles or so but the injectors are stock and have 188,000 on the car. Should I get a new injector? Can I replace just the one or should I replace all because of the miles and age? Thanks
Old 10-21-2013, 09:37 AM   #2
Replace all the injectors at once. There are a few sites that will take your old ones in as cores and send you a set of 8 rebuilt/flow tested ones for $200 I think. I'd upgrade to #21 pink top injectors while you are at it. They came on the 01.5-04 cars and the tune is the exact same. It'll run a little rich but that's how they all ran from the factory anyway.
However, don't just throw parts at it, find out exactly what the issue is. Could be the plug honestly, pull it and see. I just know what my 12 yr old injectors looked like back in 2007 when I pulled the #24s out of my 95. Literally falling apart and its a good idea to replace them.
Old 10-21-2013, 09:39 AM   #3
Rapinator126's Avatar
Try replacing the plugs first. If you swap injectors swap all of them not just one. If none of this works. Next step is a leakdown test.
Old 10-24-2013, 09:35 AM   #4
1lowGT's Avatar
I'd try new plugs. Just to be safe it's cheaper.
Old 10-24-2013, 10:10 AM   #5
Mfore33's Avatar
Well I started the car today and no engine light and it runs fine now. I guess it could have been a stuck injector or trash I the fuel. I did get gas from a place I never use.
Old 10-24-2013, 11:22 AM   #6
Might be a loose wire somewhere then or you just did get a batch of bad gas. I'd still highly recommend new injectors at that mileage/age though.
Old 10-25-2013, 08:47 AM   #7
1lowGT's Avatar
I had a bad miss and it was my passenger side far back injector that when i moved it idk if it was the wires or what but it cleared it up when i touch it so i got some tape and taped it up a little
Old 10-25-2013, 11:32 AM   #8
Mmm jerry rigging an electrical piece in the fuel system...
Old 10-25-2013, 02:31 PM   #9
1lowGT's Avatar
Lol. Well it worked and has not messed up
04:40 PM
