Lower rod knock - Mustang Evolution
Old 10-23-2013, 12:13 PM   #1
Barrett775's Avatar
Region: Wyoming
Lower rod knock
Have a lower rod knock in my engine. Was wondering if I could just buy a new block only a few hundred and transfer everything from my existing engine or would that not work. I'm not the most mechanically inclined person. I'd have a friend do the work he's a mechanic. I can find a block with internals close bye me for cheap.
Barrett775 is offline   Reply With Quote
Old 10-23-2013, 12:25 PM   #2
theweekday's Avatar
Mines started to do the same but only when the engine warms up tho. It doesn't run hot or anything
theweekday is offline   Reply With Quote
Old 10-24-2013, 04:13 AM   #3
taylor98gt's Avatar
If it jus started knocking you can just put new bearings in it. Just check the crank and rods out and make sure their not scarred up.
taylor98gt is offline   Reply With Quote
Old 10-24-2013, 07:02 AM   #4
theweekday's Avatar
What bearings? Please enlighten me more
Old 10-24-2013, 09:12 AM   #5
1lowGT's Avatar
Rod bearings. The problem isn't your block.
Old 10-24-2013, 09:46 AM   #6
theweekday's Avatar
Do I have to rebuild the motor or is it something that can be done with a drop of the pan
Old 10-24-2013, 09:12 PM   #7
1lowGT's Avatar
If you have to drop the pan you will have to drop the k member so you might as well pull the motor. I'm not sure though. I would say if its a rod bearing i would rebuild it. How many miles on your motor?
Old 10-24-2013, 10:10 PM   #8
theweekday's Avatar
This poor thing had 127k on it
Old 10-25-2013, 05:16 AM   #9
taylor98gt's Avatar
You can lolsten up the k member and drop it down a little bit and get the pan off then just start at the front and work your way back taking 1 cap off at a time and use a pick to roll the bearing out and new one in. It's a long process but if you don't wanna drop the cash on a complete rebuild it's an option to keep in mind
Old 10-25-2013, 11:49 AM   #10
Rod knock=rebuild. No two ways about it. Best bet is to find a good PI pullout from a yard guaranteed to run and just swap them out. 02-05 Explorer motors are your best option but also the priciest.
Old 10-25-2013, 12:18 PM   #11
theweekday's Avatar
I'm leaning towards the mark8 sorry for the thread jack
Old 10-25-2013, 01:11 PM   #12
Mark VIII 4V swap is also a good one but will be more costly than a simple PI pullout for $400-$900. The PI is totally plug and play, the Mark VIII will cost double that and need some modifications. Its not bad at all, like 90% plug and play but if he just needs to get his car back up and running a PI motor will be the fastest way to get there.
I've been through the whole car sitting while you rebuild the engine to be a beast and the car usually sits for a year or more if you have a full time job and a family. At least mine did... things come up... dog has to go to the vet for a $800 treatment, you have to pay off a hitman... you know life.
I will never let a car sit like that again unless its in a climate controlled garage and even then...
Old 10-29-2013, 01:15 PM   #13
V6 stang's Avatar
I thought the 4.6 was a rock hard solid motor? 130k for the rod to knock sucks.
2012 Mustang GT Convertible
Roush Exhaust
2003 Mustang GT (Sold)
Old 10-29-2013, 01:49 PM   #14
Roguestang's Avatar
It can be, hence why it was used in the crown Vic for police, taxi, etc...etc...
But it has its limits just like any other engine. That being said, they do see a lot more abuse from our crowd.
1990 Mustang GT w/ Vortech V3
***resident gun idiot***
Old 10-29-2013, 02:00 PM   #15
Seems like they built these motors as work horses huh? (Pun intended)
KoolPwny is offline   Reply With Quote
Old 10-29-2013, 02:54 PM   #16
Roguestang's Avatar
Lulz! (Ba-dum-tish!!)
Old 10-30-2013, 07:31 AM   #17
A 4.6L out of a crown vic taxi or cop car will be beat to **** more than a Mustang one will be. The best 4.6L is definitely the WAP blocked one out of a 02-05 Exploder and then one out of an old person owned Vic. And even the old person ones... going 5-10 miles each way to grocery store/lodge/church a few times a week is VERY hard on an engine, even a low mileage one.
Old 10-30-2013, 01:07 PM   #18
V6 stang's Avatar
Weird. I had the image of these motors being rock hard and only in extreme cases would they die early.
Roush Exhaust
Old 10-30-2013, 09:52 PM   #19
Roguestang's Avatar
Yeah, you basically reiterated what I said. Just with a lot more words lol
01:44 PM
