Drivers side high beam doesn't turn on - Mustang Evolution
Old 10-24-2013, 05:43 PM   #1
1997mustanggt's Avatar
My drivers side high beam doesn't turn on, but the passenger side does and the normal low beams work on both sides. Does anyone know how to fix this?
1997mustanggt is offline   Reply With Quote
Old 10-24-2013, 06:28 PM   #2
NewMtang's Avatar
Pretty easy fix, go to the Ford Dealer. All Done!
Old 10-24-2013, 06:51 PM   #3
Fader's Avatar
Region: Idaho
Sounds like the high-beam filament has broken or burned out. If your regular headlight comes on, and stays on, then it sounds like a simple bulb change. You can troubleshoot by swapping the good bulb into the driver's side, and see if the high-beam comes on. If so, just get new bulbs (best to change them in pairs), and replace.
Problem solved.
Fader is offline   Reply With Quote
Old 10-24-2013, 10:16 PM   #4
Haha.
For YOU maybe...
Change BOTH of the bulbs OP.
Old 10-25-2013, 11:39 AM   #5
Yes and take a tube of KY with you.
Problem solved.
Agreed, likely just the high beam filament is burned out. Swap the bulbs and if the problem moves to the other side there is your issue. If not you have a wiring problem somewhere.
Old 10-25-2013, 04:31 PM   #6
Sounds like the high-beam filament has broken or burned out. If your regular headlight comes on, and stays on, then it sounds like a simple bulb change. You can troubleshoot by swapping the good bulb into the driver's side, and see if the high-beam comes on. If so, just get new bulbs (best to change them in pairs), and replace. Problem solved.
Thanks for the advice I tried switching the bulbs and the drivers side works now
Old 10-25-2013, 04:40 PM   #7
both hi/lo work now
Old 10-25-2013, 06:57 PM   #8
both hi/lo work now
The drivers side high and low beam and the passenger side high beam doesn't work now so it was just the bulb that was broken
Old 10-25-2013, 09:21 PM   #9
right bulb shouldn't be more that 10-15$ at parts store or even Walmart carries em
12:05 PM
