Transmission help - Mustang Evolution
Old 10-25-2013, 03:56 PM   #1
TylerJanocha21's Avatar
Transmission help
Was pulling out of my neighborhood and went to shift from 1st to 2nd and went to let out of the clutch and it was still in 1st. Any help, also 2,3,4,5 and R don't work any help?
TylerJanocha21 is offline   Reply With Quote
Old 10-26-2013, 06:21 AM   #2
Vmcgrath's Avatar
New clutch? Sound like it burn out
Vmcgrath is offline   Reply With Quote
Old 10-26-2013, 06:41 AM   #3
nah glad it wasn't that found out the 1,2 shift fork broke in 1st which won't let it come out of 1st...simple 20$ part going to cost me 500$ to install
Old 11-11-2014, 03:53 PM   #4
madman99's Avatar
Can anyone tell me why I won't be able to use the mt82 on my 99 coyote swap. Have a good deal on buying 5.0 an trans want to know If I should buy. #Help
madman99 is offline   Reply With Quote
Old 11-11-2014, 08:05 PM   #5
Remote mounted shifter setup, trans size, crossmember setup etc... I'm sure with enough money to fab up a bunch of parts it could be done. Just get your T-45 rebuilt by Zak at The T45 Source - Proven, reliable T45 Transmissions
Old 02-04-2015, 11:38 AM   #6
madman99's Avatar
Transmission help
Will I have any fitment issues with the Tremec t56 in my new edge ? #help
Old 02-04-2015, 11:54 AM   #7
Panther140's Avatar
Doubt it. new edge cobras dont have any problems. Id like to know for sure tho
Panther140 is offline   Reply With Quote
Old 02-04-2015, 12:56 PM   #8
phillip433's Avatar
Just put t56 in mine no problems. Just the fact that I had to build my own combination ujoint for the cobra driveshaft and the gt rear end. Let me know if you need a help
2003 True Blue mustang gt
phillip433 is offline   Reply With Quote
Old 02-05-2015, 10:08 AM   #9
T56 in a NE is a pretty much bolt in affair as long as its setup for a Mustang like a Terminator trans or (better) a wide ratio magnum. You need a T-56 specific crossmember and the hybrid u joint/shorter driveshaft and that's really it. Be aware that the termi trans which is a close ratio T-56 has a 2.66 first gear vs the 3.37 first gear in a Mustang GT. This means that you need to be making enough torque to use that first gear or run MINIMUM 4.30s out back.
The only real benefit to a T-56 is 5th gear, yes 5th, not 6th. 6th is a .62 overdrive, which is what the 5th gear in all 02-04 3650s is and the .68 5th gear in everything prior to that is very close as well. Unless you need that extra gear between 4th and overdrive, I'd get a well built t45 or 3650 before I went with a T-56.
Old 09-11-2015, 07:59 PM   #10
madman99's Avatar
Who makes a good solid short throw shifter for a t-56
Old 09-12-2015, 06:10 AM   #11
Mgw or Steeda unless it's a magnum.
Sent from my LG-D801 using Mustang Evolution mobile app
Old 09-12-2015, 04:57 PM   #12
madman99's Avatar
Okay now MGW makes three different types of STS. Can someone explain to me the difference between having a 25% shift reduction or a 35% shift reduction short throw shifter ? I do have a stage two McLeod 26tooth clutch that's going to be hydro if that matters
12:12 AM
