Brake lights not working - Mustang Evolution
Old 10-25-2013, 05:56 PM   #1
Slow4V's Avatar
My lights aren't working my tails are tapped into my 3rd brake light
Any reason or fuse that deals with the 3rd brake light ??
They light up with low beams on
But don't work when I press brake
I have 01 cobra tails btw
Everything's wired correctly
Old 10-25-2013, 06:20 PM   #2
Slow4V's Avatar
Bump
Old 10-25-2013, 06:23 PM   #3
Robbiemustang96's Avatar
Check the brake light switch above your brake pedal
Robbiemustang96 is offline   Reply With Quote
Old 10-26-2013, 02:38 AM   #4
1996mustang's Avatar
Check the bulbs. They are double filament. Check to see if your turn signals work if they do then the bulbs are fine and it may be flasher or the brake switch as mentioned earlier
Old 10-26-2013, 10:17 AM   #5
Slow4V's Avatar
Wasn't Brake switch
Ending up being a blown fuse
Thanks anyways guys
Old 10-26-2013, 06:07 PM   #6
Steve96's Avatar
Originally Posted by Slow4V View Post
Wasn't Brake switch Ending up being a blown fuse Thanks anyways guys
Glad you got it fixed.
1996 GT
02:43 PM
