1997 mustang gt reverse problems - Mustang Evolution
Old 10-27-2013, 05:38 PM   #1
9stan5's Avatar
Hello just recently purchased a 1997 gt convertible.
After I purchased it started having problems reversing as the gears would grind what can I do?
9stan5 is offline   Reply With Quote
Old 10-27-2013, 09:01 PM   #2
Welcome to the wonderful world of the T-45 transmission. Nothing you can do short of a trans rebuild or swap to one that is known to not have the issue.
Try to got 1st, 1st, reverse. Or get the car moving very slightly forward, then stop and then go into reverse. Mine has trouble going into reverse sometimes but I can always get it in if I do one of those things.
Old 10-27-2013, 09:18 PM   #3
9stan5's Avatar
I love this car.i traded my red 1995 v6 for this 97 gt and I love it.thats my only issue with it.it grinds while I put it in reverse and it won't move at times.
Old 10-27-2013, 09:20 PM   #4
9stan5's Avatar
ID:	134139   Click image for larger version
Old 10-28-2013, 07:35 AM   #5
Like I said, 1st, 1st, reverse and do the roll trick. This is a known issue with the T-45s, Ford has a TSB out for it. If you get your trans rebuilt by someone like t45source they will always do the reverse fix during the rebuild for you. If you can't get it to stop doing it by one of the methods I listed well... nothing you can do short of a rebuild.
Old 10-28-2013, 12:57 PM   #6
Skulls98GT's Avatar
Same issue here. I put mine in 5th gear first, this stops the synchronizers, then with the clutch still in, shift right into reverse.
Sometimes I even have to let out the clutch a bit as I'm moving the shifter into reverse.
Skulls98GT is offline   Reply With Quote
04:12 PM
