Forged rotating assembly. - Mustang Evolution
Old 10-28-2013, 03:29 PM   #1
1lowGT's Avatar
Know the 2v rods are the weak point but is upgrading anything necessary. If so what?
Old 10-28-2013, 03:46 PM   #2
taylor98gt's Avatar
I'd do pistons while I was in there and if you plan on over 600 hp id do crank too.
taylor98gt is offline   Reply With Quote
Old 10-28-2013, 04:51 PM   #3
1lowGT's Avatar
My plan is just a rebuild so while in there, get forged. And cams, then after a while procharger.
---------- Post added at 05:51 PM ---------- Previous post was at 05:50 PM ----------
And power wise, just be able to turn it up if i want. So streetable then power.
Old 10-28-2013, 05:10 PM   #4
May as well do the job right
Old 10-28-2013, 05:15 PM   #5
1lowGT's Avatar
I didn't know what else needed forged so looks like rods pistons, stock crank is good for 600 right?
Old 10-28-2013, 05:35 PM   #6
Yeah, it's probably ok for what you want to do.
Old 10-28-2013, 05:45 PM   #7
1lowGT's Avatar
Thought so. I was looking on MMR and their kit crank pistons and rods $1499 but i wont need the crank so that should take a good bit off. Then cams, and piece together a procharge kit. For the cams what would be a good set to go with stage wise, and the stock heads okay for 450-550 hp?
Old 10-28-2013, 06:08 PM   #8
This is where it gets tricky, me giving advice on an engine build that is.
If it was me, I would build a dedicated supercharger engine if I wanted to use a blower. One with the correct compression ratio and cams. That long block wouldn't make a very good NA engine.
Same thing goes for a NA engine that I would build... It wouldn't be a good platform for supercharging.
Plenty of guys bolt superchargers on our 9.5-1 cr engines though. It's just not the route I would go personally. Im sure some of the other guys will chime in on some good cams that will work NA and FI.
Old 10-28-2013, 09:27 PM   #9
1lowGT's Avatar
I could skip cams. Would just internals and slap on a sc. I just want to make good power with little boost
Old 10-28-2013, 09:31 PM   #10
But cams sound amazing
Old 10-28-2013, 09:41 PM   #11
I think that would work great actually. If I remember correctly the stock cams are adequate for the setup that you're after.
Like SL4 said though... Cams do sound amazing.
Old 10-28-2013, 09:51 PM   #12
1lowGT's Avatar
That's why I want cd. But if they hurt performance then I don't want them. Or if they're not worth it then I'd skip
Old 10-28-2013, 09:54 PM   #13
You can probably get the power that you want without them and just keep it simple...
Old 10-28-2013, 09:58 PM   #14
1lowGT's Avatar
Keep it simple stupid. Lol. Well I mean $600 to do it. I'll think more on down the road. I'll need rods pistons procharger gears clutch and maybe flywheel.
Old 10-29-2013, 11:49 AM   #15
$600 will get you a good set of pistons. That's it.
Old 10-29-2013, 12:03 PM   #16
1lowGT's Avatar
I was meaning $600 for cams. Not the rotating assembly.
Old 10-29-2013, 12:55 PM   #17
That's just for the cams new. Forget about the TFS gears, possibly new tensioners, maybe having to pay for degree service and the custom tune. Although you're going to have to get a tune anyway.
Old 10-29-2013, 04:10 PM   #18
1lowGT's Avatar
I will probably skip cams just because if the price and tuning
Old 10-29-2013, 07:16 PM   #19
You could get some regrind cams for about $450 from Ortiz, and then put them in right before the SC and get one dyno tune.
Old 10-29-2013, 08:49 PM   #20
1lowGT's Avatar
Yeah but with boost I wouldn't need cams. So it'd be just for sound.
Old 10-29-2013, 09:57 PM   #21
Slow4V's Avatar
Uhm yeah you do need cams , cams aren't for sound obviously
Old 10-29-2013, 10:36 PM   #22
Naw. The stock cams will work for the power level that he's after.
Old 10-30-2013, 12:10 AM   #23
Exactly
Old 10-30-2013, 07:42 AM   #24
Honestly if you are after 400hp leave the stock bottom end alone. If you are after 600hp you will need cams, rods, pistons, cast crank is good to more than 600hp if staying below 6500 rpm. Also will need fuel, power adder, suspension, tires etc... this is not something you do on a budget. I mean "budget" is a relative term but to get to a reliable 600hp you're going to need upwards of $10k.
Cheapest way there would be:
-Stock block cleaned up or taken out .010 or .020
-Stock cast crank or spend a little money and get an OEM Cobra crank (I got one for free)
-2012 Boss rods
-$500 MMR/DSS forged pistons
-Ported PI heads with new springs etc...
-Stock PI intake
-Used comp 270s
-Stock trans should be ok until 500hp. If you need a rebuild its
$1k for parts and $2k total if a shop like Hanlon is doing it. If your 3650 is good you can get away with a 26 spline input shaft swap and roll.
-Centerforce clutch
-Build the rear end
-Control arms, coilovers, springs/bushings etc...
-Wheels/tires
-Vortech S trim pieced together from superchargersonline and a used headunit
-Double or triple pump setup with injectors and new rails
-Dyno tune
-Lots of nickel/dime stuff etc...
I'm sure I'm forgetting some stuff.
Like I said for a 400hp street car its very easy to just do the fuel system, slap on a blower, tune it and roll. 400whp in a well setup street car is nothing to sneeze at.
Old 10-30-2013, 07:58 AM   #25
1lowGT's Avatar
Good stuff. I would rather get forged while I'm in there so I don't have to go through this more than once. I'll look for the cobra crank which one termi? Will the stock pi heads work? Without porting what can they handle? And fuel system is where I need help and what to get for it.
Old 10-30-2013, 09:23 AM   #26
PI heads should be ported if you are looking to go much past what the stock shortblock can take. Any Cobra crank is forged, mine is out of a 98. Manual Mach 1s also have forged cranks.
What exactly are your goals with this thing?
Old 10-30-2013, 12:04 PM   #27
1lowGT's Avatar
Number wise I'm not sure. I would want to be able to turn it up and murk people. But realistically if be happy with 400 so really I would just forge it and leave heads alone. If I want more after that then I'll get the heads ported or trick flows. And get fuel system. Tranny I'll get tob replaced soon flywheel what stage clutch 2 or 3. Rear end good for how much power.
05:40 AM
