Used gears - Mustang Evolution
Old 10-30-2013, 11:11 AM   #1
calebnaasko's Avatar
Used gears
Found some used 4.10s out of a 96 gt I believe. $90 and he said the bearing is already installed so all I need is the oil.
Is this true? What else would I need to install?
calebnaasko is offline   Reply With Quote
Old 10-30-2013, 11:48 AM   #2
1lowGT's Avatar
I'd say not waste $90 on used gears. Save a little more and get new ones.
Old 10-30-2013, 12:59 PM   #3
xxPIKExx's Avatar
Agreed. I would avoid used gears as well. Just one of those things better to buy new
xxPIKExx is offline   Reply With Quote
Old 10-30-2013, 04:56 PM   #4
A new crush sleeve and a pinion seal.
I'm with the other guys though...
Unless they're free or close to it, you're better off getting a new set.
Old 10-30-2013, 08:20 PM   #5
Slow4V's Avatar
Found some used 4.10s out of a 96 gt I believe. $90 and he said the bearing is already installed so all I need is the oil. Is this true? What else would I need to install?
Just send 50 more dollars and get new ones
06:25 AM
