Help with IAT sensor - Mustang Evolution
Old 10-31-2013, 09:32 AM   #1
shawn.velez36's Avatar
Have recently put on a 90mm MAF, it requires and external IAT sensor. I have a K&N CAI and a professional products intake manifold that was done by the previous owner. I believe what he did was somehow made the IAT sensor go into the intake manifold instead of the MAF. I am now showing a check engine light because of the new MAF does have a sensor built in like the stock one does. Does anyone have any suggestions????
shawn.velez36 is offline   Reply With Quote
Old 10-31-2013, 03:44 PM   #2
cliffyk's Avatar
Running n/a the stock 80 mm MAF is good to 325+ HP at the wheels. What engine mods do you have that require the 90 mm unit?
You realise you will need a new tune to properly use that MAF, right?
Old 10-31-2013, 04:43 PM   #3
Originally Posted by cliffyk View Post
Running n/a the stock 80 mm MAF is good to 325+ HP at the wheels. What engine mods do you have that require the 90 mm unit? You realise you will need a new tune to properly use that MAF, right?
Don't have anything that really "requires" the 90mm, just wanted to add it. Yes I do realize that it requires a tune, I have already changed my tune to allow for it. So do you have insight as to how I can fix my problem??
Old 10-31-2013, 05:02 PM   #4
cliffyk's Avatar
Get an IAT sensor from an earlier 2V; 1999 to 2001, get it from a junk yard if possible so you can also get the connector and wiring; mount it in a hole in the intake tube--many CAI setups have a pre-marked or plugged hole for just that.
Connect the gray/red and gray wires from the separate IAT sensor to the gray/red and gray wires in positions 1 and 6 of the MAF connector.
FWIW the engine will run more smoothly and pull more strongly with the 80 mm MAF, as you will be using 75+% of it's metering range--as opposed to 55% or less of the 90 mm unit's range...
Old 10-31-2013, 05:24 PM   #5
Get an IAT sensor from an earlier 2V; 1999 to 2001, get it from a junk yard if possible so you can also get the connector and wiring; mount it in a hole in the intake tube--many CAI setups have a pre-marked or plugged hole for just that. Connect the gray/red and gray wires from the separate IAT sensor to the gray/red and gray wires in positions 1 and 6 of the MAF connector. FWIW the engine will run more smoothly and pull more strongly with the 80 mm MAF, as you will be using 75+% of it's metering range--as opposed to 55% or less of the 90 mm unit's range...
Thanks for the advice, I appreciate it
Old 11-06-2013, 06:43 PM   #6
Well, I went and put my new tune on today. Somehow it cleared my check engine light and I went to check the DTC code and there was nothing there!! I guess they probably do some kind of override that tell the computer that it doesn't need it. HOORAY!! NO MORE CHECK ENGINE LIGHT
Old 11-06-2013, 07:43 PM   #7
Jk it came back on!!! :,,,,(
Old 12-04-2013, 07:58 PM   #8
Alright I finally got the right harness for it. I think I have it connected right but I'm still getting the check engine light and when I check the code it's saying that the IAT sensor circuit is high. Anyone know what this means?? Anyone have any suggestions as to what I should do next??
03:59 PM
