Brake light coming on when applying brakes - Mustang Evolution
Old 11-03-2013, 06:24 AM   #1
PBrown92's Avatar
When I really get on my brakes my brake light will come on. What could be causing this?
1997 black GT
BBK CAI
SLP Loudmouth cat back
PBrown92 is offline   Reply With Quote
Old 11-03-2013, 07:00 AM   #2
ColeJohnson's Avatar
I'm sure that's just a safety thing... I have noticed that at least 100% of the time I hit the brakes my brake lights come on. Now if the brake lights dont come on... That's bad news.
2016 Comp Orange GT (current)
Old 11-03-2013, 07:39 AM   #3
schmitty426's Avatar
Low brake fluid had the same problem a few weeks ago
schmitty426 is offline   Reply With Quote
Old 11-03-2013, 07:59 AM   #4
Screaming Mach's Avatar
Mine came on when I need rear brakes don't know if its the same for 97s tho
Screaming Mach is offline   Reply With Quote
Old 11-03-2013, 08:35 AM   #5
White03GT's Avatar
+1... Dafuq
White03GT is offline   Reply With Quote
Old 11-03-2013, 09:05 AM   #6
I was just poking a bit of fun. Maybe you mean your ABS light pops on when you brake hard? Could you be a little more descriptive? Does your car hop when braking hard and does the brake pedal lose and gain pressure rapidly? Have you checked your brake fluid level? and your brake pads and rotors? The ABS sensor can get gunked up with little metal shavings and start malfunctioning a little... Cleaning that can sometimes help out a bunch.
Old 11-04-2013, 12:44 PM   #7
04beautyGT's Avatar
I can almost guarantee it's low brake fluid. While you're at it you might want to make sure you're not leaking brake fluid around the bleeder. Mine was leaking a while ago just because it wasn't tight enough. I don't know about all of the '96-04 Mustangs, but mine needed to be a little tighter than normal.
04beautyGT is offline   Reply With Quote
Old 11-04-2013, 05:30 PM   #8
Roguestang's Avatar
+1
It'll take you two mins to pop the hood and check. Definitely low on fluid.
1990 Mustang GT w/ Vortech V3
***resident gun idiot***
Old 11-05-2013, 06:54 AM   #9
PBrown92's Avatar
Originally Posted by Roguestang View Post
+1 It'll take you two mins to pop the hood and check. Definitely low on fluid.
Checked the fluid level. It was a tad bit low so I added some. Haven't taken it out for a drive yet but that was probably the issue.
1997 black GT
BBK CAI
06:50 AM
