Best Heads and cams - Mustang Evolution
Old 11-07-2013, 11:47 AM   #1
Speed_Mister's Avatar
Region: Arkansas
Best Heads and cams
Looking at getting heads and cams. What's the best out there for our 2v's?
2004 Mustang GT 5 Speed
Full Bolt Ons
370rwhp 470rwtq
12.1 @ 117.9 (1.7) in 1/4th
7.6 @ 92.1 (1.6) in 1/8th
Old 11-07-2013, 12:31 PM   #2
Depends on what else you want to have done to the car, or already have done. Stage 2 is the best for a car without much engine work done to it. Comp Cams, Hi-Tech, and CMS are all really good cams.
Old 11-07-2013, 12:38 PM   #3
Region: Arkansas
Got full bolt Ons minus headers which I'm sold with MAC's long tubes. Not gonna be spraying nitrous any. Unless it's like a small 50 or 25 shot
---------- Post added at 02:37 PM ---------- Previous post was at 02:37 PM ----------
Oh and I'm n/a right now
---------- Post added at 02:38 PM ---------- Previous post was at 02:37 PM ----------
Just want to get heads and headers and cams and be done I also got 4.10 gears
Full Bolt Ons
370rwhp 470rwtq
Old 11-07-2013, 01:31 PM   #4
Stage 2 would be best for you, usually stage 3 cams have PVC issues with stock pistons and would require aftermarket pistons. So if you don't plan on building the motor a whole lot then stage 2 would be good
Old 11-07-2013, 03:07 PM   #5
1lowGT's Avatar
25 or 50 is a waste of money
Old 11-07-2013, 03:10 PM   #6
Region: Arkansas
Which is why I'm not gonna do it
Full Bolt Ons
370rwhp 470rwtq
Old 11-07-2013, 03:13 PM   #7
1lowGT's Avatar
It's worth a 100 no less than 75
Old 11-07-2013, 03:21 PM   #8
Region: Arkansas
I don't trust nitrous enough I just wanna do full bolt ons which all I got left is really cams heads and headers. Could I just get my heads ported? Is it worth it and how much does it cost?
Full Bolt Ons
370rwhp 470rwtq
Old 11-07-2013, 04:00 PM   #9
1lowGT's Avatar
It's safe wet shot is good. You could because heads are expensive idk how much port cost
Old 11-07-2013, 04:59 PM   #10
If you don't mind spending a nice chunk of $ this is something you would like.
CMS/MHS 2V Modular Head/Cam Package Stage 3 - Cushman Motorsports
You get the stage 3 heads, and can pick between which cams you want. Remember that more aggressive cams will raise the rpm up higher in the powerband, so pick which ones will be best suited for you. This should let you rev up to 7k
Old 11-07-2013, 07:35 PM   #11
1lowGT's Avatar
Truck flows a good head too
Old 11-07-2013, 07:40 PM   #12
Region: Arkansas
So apparently trick flow heads are the way to go
Full Bolt Ons
370rwhp 470rwtq
Old 11-08-2013, 06:47 AM   #13
1lowGT's Avatar
They are. But they're expensive. Look into port and polished pi heads and see how much it costs. It's cheaper I know but not sure how much. Trick flows, flow better out of the box better than port and polished pi heads but they are pricey.
Old 11-08-2013, 06:51 AM   #14
2300turboford's Avatar
Trickflow !!
Old 11-08-2013, 08:44 AM   #15
Yeah trick flow claims gains from ~380 to 390hp
With their h/c/I combo
I'm willing to bet that's crank hp though
KoolPwny is offline   Reply With Quote
Old 11-08-2013, 09:01 AM   #16
Region: Arkansas
So now what about cams?
Full Bolt Ons
370rwhp 470rwtq
Old 11-08-2013, 10:42 AM   #17
1lowGT's Avatar
Either it is at crank or they're way off
Old 11-08-2013, 02:40 PM   #18
Houston performance 292
Cushman motorsports stage 2 blower cam
Comp cam 262
Comp cam 270
There's a bunch of good ones
Old 11-08-2013, 02:43 PM   #19
Region: Arkansas
Originally Posted by Bee20e View Post
Houston performance 292 Cushman motorsports stage 2 blower cam Comp cam 262 Comp cam 270 There's a bunch of good ones
I was thinking cms stage 2
Full Bolt Ons
370rwhp 470rwtq
Old 11-08-2013, 03:00 PM   #20
Those are good ones also.
Old 11-08-2013, 03:08 PM   #21
You should get some blower cams. They work good n/a and when work excellent when blown!
07:48 AM
