96 GT Supercharger Dyno Run - Mustang Evolution
Old 11-09-2013, 07:37 PM   #1
Lapida's Avatar
I have a boost leak to solve. Only 7 pounds of boost instead of 12. I think the EGR opens during boost.
http://youtu.be/bjy3RDKBLwA
Lapida is offline   Reply With Quote
Old 11-12-2013, 05:54 AM   #2
1996mustang's Avatar
Imo i dont think a egr would affect boost performance since its only function is to recirculate exhaust gas into the intake to help "cool" the cylinders down. However easy fix would be just remove and plug the vacuum hose going to it. My opinion if you are being restricted on boost check your setup check the hoses and vacuum lines going to the gauge and such. Also how much are you pushing injector wise and what is the setup you run?
05:11 PM
