Embarrasing Steering Creak? - Mustang Evolution
Old 11-10-2013, 12:17 AM   #1
ccabral14's Avatar
My 02 Gt has been making this really loud creaking noise when turning the wheel at low speeds and I finally have time to get around to it. I don't think it's struts because it doesn't do it over bumps, it only happens when the wheel is being turned side to side, if I make a sharp turn it only creaks at the beginning of the turn. Is it ball joints? Tie rod? Steering rack bushings? (The suspension is all stock besides rear shocks and it has 192k)
ccabral14 is offline   Reply With Quote
Old 11-10-2013, 12:19 AM   #2
PonyBoyV6's Avatar
ball joints. 90% sure. I dealt with this same thing on my 02 about 5 months ago.
PonyBoyV6 is offline   Reply With Quote
Old 11-10-2013, 12:20 AM   #3
ccabral14's Avatar
Do they need to be greased (if possible) or replaced?
Old 11-10-2013, 12:32 AM   #4
PonyBoyV6's Avatar
Stock, i believe the mustangs do not come with greaseable ball joints. If yours are aftermarket. Then they should be greaseable.
Old 11-10-2013, 12:42 AM   #5
probably the ball joints... Have you checked your power steering fluid though?
Old 11-10-2013, 12:47 AM   #6
Slow4V's Avatar
Maybe the sway bar end links
Old 11-10-2013, 02:36 AM   #7
MidnightBlueGT's Avatar
I agree check your ps fluid. The ps pump is notorious for squealing and happens fairly often in our cars so Im told.
Old 11-10-2013, 07:15 AM   #8
Steering rack sleeves, start here, cheap fix, possibly get new bushings to
http://www.svtperformance.com/forums...rning-fix.html
Old 11-10-2013, 08:05 AM   #9
04sonicbgt's Avatar
Mine is doing the same exact thing, gonna take a look at a few things today and see if I can't get it fixed.
Sonic blue 04 GT~~bolt ons- headers, steeda tri ax, hi tech stage 2 cams coming this winter.
04sonicbgt is offline   Reply With Quote
Old 11-10-2013, 08:28 AM   #10
ccabral14's Avatar
Thanks for all the replies guys, I think I'm going to start with the svtp fix, it sounds easy and cheap. I'm hoping that will fix the problem but I did see a video on YouTube where a mustang was making a sound very similar to mine and his problem was ball joints. How would I go about checking if my ball joint are bad?
Old 11-10-2013, 09:21 AM   #11
jduckz5.0's Avatar
Get someone to turn wheel back n forth so you can get idea where noise is coming from...spray some penetrating lube where u think it's coming from...it will go quiet for a lil bit so you'll know what to replace...
jduckz5.0 is offline   Reply With Quote
Old 11-10-2013, 10:30 AM   #12
JayStang718's Avatar
I had a similar sound ended up being ball joints
JayStang718 is offline   Reply With Quote
Old 11-10-2013, 12:53 PM   #13
ccabral14's Avatar
That sounds very similar to mine, except yours sounds about 10 times worse. Mine only squeaks at the start of turning the wheel, for example if you put your hand at 12 on the steering wheel And turn to 2 it will squeak but past that it won't.
Old 11-10-2013, 01:01 PM   #14
Slow4V's Avatar
Sway bar end links ..
Or why haven't you already lifted the car up and looked for yourself ?
Old 11-10-2013, 02:06 PM   #15
ccabral14's Avatar
Figured I would get some insight first, thanks for all the replies everyone
Old 11-11-2013, 06:19 AM   #16
Wink Ford TSP 05-14-3
I had the same issue and found this answer on this forum. I did it and it worked great for me - no more noise. Ford has a service bulletin on steering noise creek for 2002 - 2004 Mustangs - and have a replacement part fix. This guy had a home solution. It took me a little over an hour to do. Hope this helps.
PaladinMicro#
John3799 is offline   Reply With Quote
Old 11-12-2013, 11:03 AM   #17
v8pony's Avatar
Had the same problem, turned out to be my tie rod end boots were dried up, there not serviceable, but mine had 0 play, so punctured a needle sized hole in the boot, pumped it up with white lithium grease, sealed the hole, no noise since than about 8 months ago...
2002 5spd GT
Feb 2013 Mustang of the Month
Old 11-16-2013, 12:11 PM   #18
ccabral14's Avatar
We'll it appears to be coming from the passenger side ball joint, there's no grease fittings, no play in the wheel. The front end is tight, no wandering. Is the ball joint bad?
Old 11-16-2013, 11:02 PM   #19
Probably.
I just replaced every part in my front end. The steering rack bushings were worn out. Both of the inner tie rods and one outer tie rod was bad. Both of the ball joints were weak as well. Also, the strut bushings needed replacing.
I recommend replacing everything. My car drives beautifully now. Just like brand new. All of the strange noises are gone.
Old 11-16-2013, 11:15 PM   #20
ccabral14's Avatar
Eventually I'll get through the whole front end, but for now I'm going to order the steeds ball joints and see what that solves, if the sound is gone I'll be happy
Old 11-16-2013, 11:22 PM   #21
That's a good start.
Have a look at the strut bushings. Everyone overlooks them.
01:56 AM
