What is this electrical connector on my passenger door? - Mustang Evolution
Old 11-12-2013, 09:20 AM   #1
surfinglbi23's Avatar
Hey all - swapping out my window switch and door lock actuator. Remove door panel and see this little white connector. What is it and what is it for? See close up in second picture.
Bottom right, little white connector. Probably can best see it in the third picture.
1994 Mustang Gt but I am posting here for the overlap in body style. Power windows and locks.
ID:	136133   Click image for larger version
surfinglbi23 is offline   Reply With Quote
Old 11-12-2013, 09:37 AM   #2
clflorida's Avatar
Region: Arkansas
The wire its attached to is for the window locks. Uh is you actuator in there? That..oh ill go look. I havent had my door panel on for a month or two :p
clflorida is offline   Reply With Quote
Old 11-12-2013, 09:48 AM   #3
clflorida's Avatar
Region: Arkansas
It kinda looks like yours is in the middle but look inside and you should see this. Thats the white connector. If your power locks work you should have an actuator(the box my white connector is attached to).
Old 11-12-2013, 09:54 AM   #4
Yes, the actuator is in the there ... the power locks are not working on the passenger side but the actuator is connected and makes a buzzing noise when the button is pressed. Hence the reason for swapping it out. I just can't figure out that little connector! If you have a chance to check, I'd greatly appreciate it.
---------- Post added at 11:54 AM ---------- Previous post was at 11:52 AM ----------
Hmmm ok now I'm confused. I have a black round motor thing attached to the actual lock rod, and when the button pressed I hear a noise, are there more than one motor/actuator things that are connected or just what you pictured above?
Old 11-12-2013, 09:57 AM   #5
Fader's Avatar
Region: Idaho
Does your Mustang have the little red lights on the door panel? The ones to make the door visible from the rear if they're open? They are usually in that area of the door?
If not, then I haven't a clue.
Fader is offline   Reply With Quote
Old 11-12-2013, 10:00 AM   #6
No little red lights. Perplexing problem isn't it? I believe I need a new actuator as the driver side works great and passenger side just seems to "spin" making a noise and not catching. So I will order a new actuator. If the doors work and window works, I'm not terribly concerned about it.
Does anyone have keyless entry? That was my only other thought, some tie in for a remote clicker. I don't have it so I don't know
Old 11-12-2013, 10:07 AM   #7
clflorida's Avatar
Region: Arkansas
I had to replace mine too. It made a noise like it was unlocking but you could see the lock barely move. Like he wasnt strong enough to make it all the way.
Old 11-12-2013, 12:16 PM   #8
Mine makes a noise similar to the convertible top but a bit more shrill. It's worth trying to grab a new actuator I think. Ill trace that wire when I'm in there again to see if I can sort it. Thanks for the help
Old 11-12-2013, 02:55 PM   #9
clflorida's Avatar
Region: Arkansas
No problem man. Keep us posted on how it works out.
07:09 PM
