HELP!! P0141 Code - Mustang Evolution
Old 11-13-2013, 08:57 PM   #1
HELP!! P0141 Code
I've been having some issues with my car passing smog and I'am in need of some advice.
I took the car to see if it would pass smog and the gentlemen told me that the readiness monitors were not ready. He also notice when he drove the car that it was running way to rich and recommended that I change the O2 sensors.
So long story short, I replaced all four sensors (smell went away) and drove it about 120 miles. Once i got home I checked the computer and it threw this code: P0141.
P0141- OXY SENS HEATER CIRC ( BANK1-SENSE2). What does this code mean? Is the sensor bad? The wiring to the sensor bad? Please help..Thanks!
Adl_s07 is offline   Reply With Quote
Old 11-13-2013, 09:10 PM   #2
03Graymach's Avatar
Originally Posted by Adl_s07 View Post
I've been having some issues with my car passing smog and I'am in need of some advice. I took the car to see if it would pass smog and the gentlemen told me that the readiness monitors were not ready. He also notice when he drove the car that it was running way to rich and recommended that I change the O2 sensors. So long story short, I replaced all four sensors (smell went away) and drove it about 120 miles. Once i got home I checked the computer and it threw this code: P0141. P0141- OXY SENS HEATER CIRC ( BANK1-SENSE2). What does this code mean? Is the sensor bad? The wiring to the sensor bad? Please help..Thanks!
Causes of Oxygen Sensor Trouble Codes P0133 P0135 P0141
Oxygen sensors monitor the amount of oxygen in the exhaust so the engine computer (PCM) can adjust the fuel mixture to minimize emissions and maximize fuel economy. There are two types of oxygen sensor trouble codes: O2 heater circuit codes and O2 sensor codes. A heater codes will set if a fault is detected in the circuit that warms up the oxygen sensor when your engine is first started. This is necessary to reduce cold start emissions. An O2 sensor performance code will be set if the O2 sensor readings remain low (lean), or high (rich), or do not change quickly enough, or do not change at all.
A low voltage (lean) oxygen sensor reading may indicate the sensor has failed, or that it is being "fooled" by an exhaust manifold vacuum leak, or a condition that allows unburned oxygen to enter the exhaust such as a burned or bend exhaust valve, or a misfiring spark plug.
NOTE: If you get an oxygen sensor code plus a random misfire code and/or a MAP sensor code, the engine probably has a serious vacuum leak.
---------- Post added at 10:10 PM ---------- Previous post was at 10:09 PM ----------
Originally Posted by 03Graymach View Post
Causes of Oxygen Sensor Trouble Codes P0133 P0135 P0141 Oxygen sensors monitor the amount of oxygen in the exhaust so the engine computer (PCM) can adjust the fuel mixture to minimize emissions and maximize fuel economy. There are two types of oxygen sensor trouble codes: O2 heater circuit codes and O2 sensor codes. A heater codes will set if a fault is detected in the circuit that warms up the oxygen sensor when your engine is first started. This is necessary to reduce cold start emissions. An O2 sensor performance code will be set if the O2 sensor readings remain low (lean), or high (rich), or do not change quickly enough, or do not change at all. A low voltage (lean) oxygen sensor reading may indicate the sensor has failed, or that it is being "fooled" by an exhaust manifold vacuum leak, or a condition that allows unburned oxygen to enter the exhaust such as a burned or bend exhaust valve, or a misfiring spark plug. NOTE: If you get an oxygen sensor code plus a random misfire code and/or a MAP sensor code, the engine probably has a serious vacuum leak.
Hope this helps
03Graymach is offline   Reply With Quote
Old 11-13-2013, 09:18 PM   #3
Hope this helps
Helps me out a little. Still confused on what should be done. Should I just replace the O2 Sensor?
Old 11-14-2013, 05:58 AM   #4
Well you said your already replaced all 4 right? If so, it's possible I guess one if the new ones is bad, but that code could also signify you have a vacuum leak.
There are some how to vids out there in YouTube to help you try and track that down.
All else fails, take it to your trusted mechanic
Old 11-14-2013, 06:42 AM   #5
03Graymach's Avatar
What's it's saying is that yes one of the new ones could be bad or you have a vacuum leak or a bad spark plug causing it to run real rich. I can tell you the problem is in the front 2 o2 sensors if it's one of then but I would replace spark plugs first before you leak check it
Old 11-14-2013, 11:26 AM   #6
cliffyk's Avatar
P0141, HO2S Sensor Circuit Malfunction (HO2S-12) indicates the heater in the passenger side rear O2 sensor did not pass the I/M tests--it has the same possible causes as P0135.
Here is what the shop manual says about P0135, including possible causes and diagnostic tips.
It could just not be plugged in properly...
Old 11-14-2013, 01:46 PM   #7
Constantine's Avatar
MIL eliminators from americanmuscle.com
Constantine is offline   Reply With Quote
Old 11-14-2013, 02:45 PM   #8
cliffyk's Avatar
MIL eliminators will not correct a heater malfunction; except that the act of installing them might correct an electrical connection problem...
Old 11-14-2013, 02:52 PM   #9
Oops. You're right. Sorry, I got my codes mixed up.
03:54 PM
