HID Help! - Mustang Evolution
Old 11-14-2013, 04:39 AM   #1
to_oaxaca's Avatar
Region: Nevada
HID Help!
I need help putting and HID Kit into my 00' mustang, someone told me i might need a relay or bypass but I'm not sure if i do, thanks!
to_oaxaca is offline   Reply With Quote
Old 11-14-2013, 09:23 AM   #2
mustang17's Avatar
You may but i don't think so i didn't need one for my mustang i needed one for my old jeep though. If you know what your doing throw them in and see if the lights flicker than you need a relay if not then you're good to go
mustang17 is offline   Reply With Quote
Old 11-14-2013, 10:01 AM   #3
Mile high JDF's Avatar
It looks like you have everything needed to install it. I didn't need to bypass a relay for mine.
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 11-14-2013, 11:57 AM   #4
to_oaxaca's Avatar
Region: Nevada
Thanks guys, In gunna put them up and see if they need it
Old 11-14-2013, 12:06 PM   #5
Which kit did you go with?
Old 11-14-2013, 12:08 PM   #6
mustang17's Avatar
let us know
HIDs, 20% tint, Mach 1 chin spoiler, Black bullitt wheels, White bumper inserts, Shorty antenna
Old 11-14-2013, 12:17 PM   #7
to_oaxaca's Avatar
Region: Nevada
Im guessing its just a generic 8000k hid kit, got it in LA, its cheaper than LV
& also one more question, would my sound system affect the HIDs in any way?
Old 11-14-2013, 12:30 PM   #8
mustang17's Avatar
It affects mine alot, the moron i brought them to install mine must have f**ked mine up because i get static if my lights are on. I don't know why but it also happens to me maybe someone else can answer it for me too? What can i do?
Old 11-14-2013, 12:32 PM   #9
Get rid of the pos "hid" lights and run something legal.
Old 11-14-2013, 12:33 PM   #10
mustang17's Avatar
thanks for the help
Old 11-14-2013, 12:48 PM   #11
thanks for the help
You're welcome.
Old 11-14-2013, 01:43 PM   #12
to_oaxaca's Avatar
Region: Nevada
So ger rid of them?
Is there any way around it?
---------- Post added at 11:43 AM ---------- Previous post was at 11:42 AM ----------
You have a sound system and HiDs? How is it working for you?
Old 11-14-2013, 01:55 PM   #13
So ger rid of them?
The only safe way to run HIDs in our headlights is to do a retrofit on them, I don't know of that makes them legal or not but that's about the only way Lowflyn will back off on the HID subject
Old 11-14-2013, 02:10 PM   #14
mustang17's Avatar
He probably still won't
Old 11-14-2013, 02:20 PM   #15
to_oaxaca's Avatar
Region: Nevada
What do you mean retrofit?
Old 11-14-2013, 02:41 PM   #16
Buy a housing that is designed to aim the light from a hid bulb instead of designed to scatter light from a halogen.
Regardless i'm not a big fan of giving probable cause to be pulled over.
Old 11-14-2013, 02:42 PM   #17
http://www.yukeshidretrofits.com
If I had the cash I would do them but that's a lot of money to toss on a set of headlights.
Old 11-14-2013, 02:45 PM   #18
thejohncarlson's Avatar
I have retrofits in mine and no, it does not make it legal. It does make your headlights much better because the light is focused properly and not scattered the way they are with reflectors.
My setup was about $600.00. Not bad considering they are Morimoto hids which cost about $200 or so.
thejohncarlson is offline   Reply With Quote
Old 11-14-2013, 03:23 PM   #19
to_oaxaca's Avatar
Region: Nevada
do you have a sound system? if so does it make the HIDs flicker bad? and do I run the risk of having them burn out with the sound system?
Old 11-14-2013, 03:27 PM   #20
mustang17's Avatar
No i dont have a system i have stock. it just gives off static it wont burn out the system either. If they flicker you need a relay but 95% chance you wont need one
Old 11-14-2013, 03:30 PM   #21
to_oaxaca's Avatar
Region: Nevada
Alright thanks for the info, I appreciate it! I'll have to wait till it gets dark here in Vegas to see how they look, I already installed them.
Ill upload a picture later.
Old 11-14-2013, 03:57 PM   #22
mustang17's Avatar
Alright thanks for the info, I appreciate it! I'll have to wait till it gets dark here in Vegas to see how they look, I already installed them. Ill upload a picture later.
No problem man
Old 11-14-2013, 04:43 PM   #23
So seriously a system messses up your hid haha Wtf I know someone pushing a 800 watts rms of bass with 8k hids with no problems. I have no hids (yet) on my sixxer but it's fun seeing my lights dim with the bass
Old 11-14-2013, 04:50 PM   #24
to_oaxaca's Avatar
Region: Nevada
Yea thats what im saying, I have a 1200 watts system and with the halogens, the light would dim with the bass, and I was worried that it might burn the lights out, should I worry still because theyre HIDs?
Old 11-14-2013, 04:54 PM   #25
They don't dim for him. My old system (2 tens) in my marquis wouldn't make my hids dim but that was a small setup so idk
Old 11-14-2013, 06:15 PM   #26
to_oaxaca's Avatar
Region: Nevada
I have 2 12's , I dont have that one cylinder most people use for the systems; idk what its called, but my only concern is, should I worry about the system messing the HID's up?
Old 11-14-2013, 06:24 PM   #27
Capacitor? My single 10 doesn't do anything but it shouldn't draw enough power to affect anything.
Old 11-14-2013, 06:56 PM   #28
No dude your good.
Real world experience
Old 11-14-2013, 07:12 PM   #29
to_oaxaca's Avatar
Region: Nevada
Okay so i already installed them and they flicker a little bit
Old 11-14-2013, 07:24 PM   #30
Do both flicker? Does it go away after they have been on awhile?
Old 11-14-2013, 08:14 PM   #31
to_oaxaca's Avatar
Region: Nevada
Yea they both flicker and I drove for about 30 minutes, and when i came to a stop and checked them out thats when i noticed they were flickering
Old 11-14-2013, 08:32 PM   #32
You might need a relay.
The reason I asked was that I had some hids that looked just like those that would flicker for a couple of minutes and then stop and it ended up being bad ballasts.
Old 11-14-2013, 08:53 PM   #33
Mustang 4pt0's Avatar
HIDs are legal here...
Mustang 4pt0 is offline   Reply With Quote
Old 11-14-2013, 09:07 PM   #34
It is actually federal law that makes them illegal so, they are illegal there as well.
Old 11-14-2013, 09:10 PM   #35
Slow4V's Avatar
I've owned 5 sets on different cars , never did I need a relay
They only flicker when you have cheap ballasts
01:08 AM
