5th GEAR - Mustang Evolution
Old 11-14-2013, 01:16 PM   #1
5th GEAR
When I go to put it in 5th gear it just grinds unless i pump the clutch several times then i just get lucky..
Also my main bearing has worn a ridge into my clutch fork.
Please help! Young and don't know much HAHA!! Thank you!!
tommyfinley109 is offline   Reply With Quote
Old 11-14-2013, 11:00 PM   #2
1lowGT's Avatar
Wait main and clutch fork I'm confused. I guess I'm not aware of that. Gear problem- what tranny you got tr3650 is noisy and my shifter area is loud but that's because of the tr3650 yours might be the throw out bearing. I know mine is going bad too.
Old 11-14-2013, 11:16 PM   #3
ColeJohnson's Avatar
I know with my old stock set up I had I push the clutch down further than usual and slowly and deliberately put it into fifth to get it to go in without any back talk.
2016 Comp Orange GT (current)
Old 11-15-2013, 08:09 AM   #4
1lowGT's Avatar
I haven't had those problems. Only problems is when it's cold and car ain't warmed up when I pull it back to go into 2nd it kinda whines/grinds not gears but idk what but only when its cold.
Old 11-15-2013, 08:16 AM   #5
04sonicbgt's Avatar
mine does this same exact thing on cold mornings.
Sonic blue 04 GT~~bolt ons- headers, steeda tri ax, hi tech stage 2 cams coming this winter.
04sonicbgt is offline   Reply With Quote
Old 11-15-2013, 08:21 AM   #6
1lowGT's Avatar
I try to let it warm up but usually don't have time. So I mope to class until it's warmed up
Old 11-15-2013, 09:21 AM   #7
v8pony's Avatar
Exact problem here
---------- Post added at 11:21 AM ---------- Previous post was at 11:20 AM ----------
Me too, I drive like a grandma in a Buick until I reach normal temp
2002 5spd GT
Feb 2013 Mustang of the Month
Old 11-15-2013, 09:41 AM   #8
04sonicbgt's Avatar
Originally Posted by v8pony View Post
Exact problem here ---------- Post added at 11:21 AM ---------- Previous post was at 11:20 AM ---------- Me too, I drive like a grandma in a Buick until I reach normal temp
that first shift of the morning going into second is a rough one
Old 11-15-2013, 09:56 AM   #9
1lowGT's Avatar
That's for sure I pull back so easy and slow lol
Old 11-15-2013, 11:40 AM   #10
v8pony's Avatar
Ohhhh yea super slow, i cannot stand it, wanna know the worst part, I literally live on a major highway which is usually congested especially during rush hour, so whenever I leave my driveway, I have no choice but to immediately merge in and go 60MPH, that 1-2 shift ughhhh lol
2002 5spd GT
Old 11-15-2013, 03:06 PM   #11
calebnaasko's Avatar
My 5th gear grinds too. And one time I pulled it out of 5th and the whole neutral section was very stiff and hard to move.
calebnaasko is offline   Reply With Quote
Old 11-15-2013, 08:46 PM   #12
v8pony's Avatar
weird.
2002 5spd GT
Old 12-01-2014, 11:09 AM   #13
fenixignition's Avatar
Havent quite had that issue.
havent noticed any issues with 2nd when its cold, even less after switching to synchromesh.
sorry to ressurect an old thread guys, but I've been searching, and still turning up nothing with this 5th gear problem. best ive found is that people just leave it and keep driving.
Its pretty unnerving, hearing that grinding/rattling/ wet rocks in a tumbler/ air in a straw noise. however you wanna describe it. but after the tranny fluid warms up, its GONE. so i know the obvious answer it, "Well, let it warm up". but its still uncomfortable not knowing why it makes that noise.
I had almost 4 qts of mobil1 atf in it at one point, and it almost never made the noise. when it did briefly, it sounded muffled by the oil. with 3 quarts of synchromech, it would happen no matter what and stay. 3.5 qts, it at least goes away when warm.
How does the lubrication work inside the 3650? it just splashes fluid all over itself, right? no tight tolerances like in the engine?
2002 GT 5sp. 16x,xxx miles
« Stereo | Springs »
12:13 AM
